Help!!!!!!
The Timing belt broke on my car a few months ago and im coming around to getting it fixed now. I have a few Questions if anyone could please answer them.
Does anyone have a picture or know where i can find a picture of the firing order of the cylinders and where they are?
How do you make sure the cams and the crank are in time?
And is there a metal timing chain behind the belt?
If anyone could get back to me as soon as possible with any or all of these answers it would be greatly appreciated. Thanks
1-2-3-4-5-6 I believe and The cam and crank question I'm not sure and yes there is a metal timing chain behind the belt.
If I was you I would get a how to book before you take it on. :wink:
Jud
Jud
Im not doing it myself...a local shop is doing it for me.
Do a search on here and the v6 forum. I have seen pictures on one or the other or both. :)
Jud
So there is two? a timing chain and a timing belt? or are you meaning the regular belt and a metal timing chain?
Yes, there is a kevlar secondary timing belt to run all four camshafts.
That belt connects to the main camshft spocket down below to where the timing chain is; connect that to the crankshaft.
Firing Order: 1-2-3-4-5-6
Coil Connection Sequence: 1-4-6-3-2-5
- Erik
