Half-shaft removal.
I'm trying to take out the drivers side half shaft on my 92 Lumina. I've got a hub puller, and i've got the hub seperated from the control arm. How do I get the half shaft out of the transmission?
just get a big pry bar, I had the same problem, there is a snap ring holding it in
I agree.......you just have to pull on it really hard.....it took me, my dad, and my mechanic friend about 2 minutes with all three of us yanking on it...
SmoothSteve
noo not good the cv joint will come right out of the socket
best way is like mention before
the way to do it is get the pry bar between the case and axle and pry it out that way
be glad that you didn't seperate the cv joint and rip the boot
good luck
Yeah, I didn't pull on it for specifically that reason. Gotta find a smaller prybar now. Thanks everyone
i used a big screwdriver. but yeah, the slide hammer is what you're suppesed to use cough....screwdriver...cough. but only cuz i couldn't seem to fit a pry bar in to get it out
I got a crow bar and put the straight side up behind one of the 3 buldges in the thing, then jammed the crow bar between the sway bar and subframe to use as fulcrum. One swift kick on the crow bar and the thing will pop out.
yep, what those guys said. very easy to remove.
