cooling fans
93 Grand Prix
What could be wrong if my cooling fans don't come on? i replaced the thermostat and water pump a few days ago! Does the cooling fans help pump coolant? Let me know so I won't blow my engine.
fan relays not making contact or fried.
fan motors burned out.
fans not pluged in harness.
You will start to over heat if you sit idle a long time without fans.
First of all, check your fuses for your fans. They are under the hood on the passenger side towards the front, there are 2 of them. If those check out good, replace your fan switch, and that is a bitch to get to. Its right above the exhaust manifold. Check the connections to the fans to, and make sure that the motors aren't burnt out on them.
Aaron
