front swaybar
would I gain alot if I put another swaybar on the bottom of the cradle?
I'd put it directly under the upper one. or would I gain more from a rear upgrade?
marcus
What kind of ghettofabulous engineering are you talking about here? :lol:
If your front sway bar isn't enough, just swap it out for the 34mm one.
That's a bigger front sway bar than most people have ever seen on a car. I remember the junkyard guys I bought mine from said, "whoa, that's the biggest sway bar I've ever seen".
I don't know that I saw much gains going from 30mm to 34mm, but I had worthless General tires that squeal on every turn. You would definitely gain more from a rear upgrade, but oversteer on a FWD isn't nearly as predictable as on an RWD.
