Guest Anonymous Posted March 5, 2004 Report Posted March 5, 2004 Would this cause too much strain on the electrical system? http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33710&item=2463334236 Quote
5speedz34 Posted March 5, 2004 Report Posted March 5, 2004 IDK, but I like how hes like it works on my chevy but yet its for a GP Quote
hazmatic Posted March 5, 2004 Report Posted March 5, 2004 thats actually for any car and yes its a strain but not a big strain on the eltrical system Quote
Justin Posted March 5, 2004 Report Posted March 5, 2004 I love how he's charging $24.00 for a relay and some scotchlocks... There's like $5.00 worth of electrical parts there, and you'll be lucky if your headlights work at all after you've scotchlocked into them, they'll corrode the wires after maybe a year. Quote
hazmatic Posted March 5, 2004 Report Posted March 5, 2004 u can do this for free if your not afraid to do a littel research on your electrical system n n not afradi to splice wires and what not its actually a simple and easy mode that can be done for free Quote
LukeZ34 Posted March 5, 2004 Report Posted March 5, 2004 I believe any Gm car with the Miniquads uses all 4 lights for 'brights'. Corrosion with that kit would be an issue. Soldering the connections, vinyl tape and heatshrink tubing are a must for this project. Quote
GnatGoSplat Posted March 5, 2004 Report Posted March 5, 2004 I think it is too much strain on the firewall connector. Mine fried, and all I did was bump up the 55W foglights to 100W. I would definitely get one of those heavy duty headlight harnesses with relays if you want to run all 4. Anyway, I think that kit isn't even necessary. While looking at the schematic for my 89, it looks like all you have to do is bridge 2 wires at the high beam switch. I plan to do this mod as soon as I get my heavy duty headlight harness in. Quote
digitaloutsider Posted March 5, 2004 Report Posted March 5, 2004 Auction ended. I'm glad no one bought that. $24.. shit. Quote
WhiteOut Posted March 5, 2004 Report Posted March 5, 2004 I believe any Gm car with the Miniquads uses all 4 lights for 'brights'. Corrosion with that kit would be an issue. Soldering the connections, vinyl tape and heatshrink tubing are a must for this project. Yeah, all of the cars with mini quads use both the brights and the low beams when you turn on your brights. The only thing that goes off is the fogs. Quote
ismellrealbad Posted March 5, 2004 Report Posted March 5, 2004 same. my hi's and lows run and fogs shut off Quote
runt Posted March 6, 2004 Report Posted March 6, 2004 I'm guessing it's for RedTurbo's White GP Turbo project? I think that would be a hurt on the system. Then again, the mini's do use all four... Quote
