Cartracer Posted March 5, 2004 Report Posted March 5, 2004 whenever i open my door it makes a cracking noise. i found out that it is located on the botton part of the door where it pivots to swing open. i was wondering if anyone knew what this part was called or how much it costs? Quote
Bake82 Posted March 5, 2004 Report Posted March 5, 2004 Mine did that too. try tighting all the bolts in the door jam. Solved my problem. Also try lubricating the whole door jam. Good luck. Quote
93CutlassSupreme Posted March 5, 2004 Report Posted March 5, 2004 whenever i open my door it makes a cracking noise. i found out that it is located on the botton part of the door where it pivots to swing open. i was wondering if anyone knew what this part was called or how much it costs? mine does the same thing hmmm never thought about tightening the bolts Quote
Bake82 Posted March 5, 2004 Report Posted March 5, 2004 Yah mine kind of moved too whenever the cracking noise happened. So I tightned the bolts and it went away! If your door moves when it makes the noise, definetly tighten up the bolts! Quote
Cartracer Posted March 5, 2004 Author Report Posted March 5, 2004 lol i guess that sounds like a smart thing to do well i will try that and hopefully fix the problem Quote
paulo57509 Posted March 7, 2004 Report Posted March 7, 2004 Check the door "link" (the hold open thing) too. Mine was making a terrible clunking noise and then after a while it went away and the door became "loose". Turns out one of the mounting ears on the link broke and the remaining ear eventually tore off part of the door. Quote
