Invasion1
W/ the lower intake gasket set, or not? I have both sitting out in the garage.
WARNING: FWIW, Do not use the fel-pro head gaskets. They have a thinner compressed thickness than the GM's. GM is like .0072 and fel-pro is .005something. Not much difference but it is your heads/motor/more labor that will suffer. I used fel-pro and did everything correct, rear gasket failed. Went to GM and have had no problems. Dale Omaha, NE.
