Maverick Posted February 29, 2004 Report Posted February 29, 2004 When I flick on the hazard lights, the front ones come on, but the rears dont do shit. Any suggestions? Quote
Slade901 Posted February 29, 2004 Report Posted February 29, 2004 Does the turn signal lights on the rear works at all? If the turn signal lights at the rear does not work then the hazard lights is not going to work either. Quote
GPdriver1986 Posted February 29, 2004 Report Posted February 29, 2004 ok, there are 2 switches, one is for the emergency flasher and the other one is for the normal flasher. You might want to try to replace the emergency flasher unit its underneath the glove box. Quote
Maverick Posted February 29, 2004 Author Report Posted February 29, 2004 The rear signals work. Underneath the glove box? Is it a switch like the hazards off the steeringwheel column? Quote
GPdriver1986 Posted February 29, 2004 Report Posted February 29, 2004 its this silver round thing that makes the lights turn off and on, perhaps the wire came loose for the rear ones or you might have to replace it. The relay switch for the normal turn signal is around the steering colmun except it only turns on for one side instead of both. Quote
digitaloutsider Posted February 29, 2004 Report Posted February 29, 2004 The rear signals work. Underneath the glove box? Is it a switch like the hazards off the steeringwheel column? It's right next to the C200 connector. It's on the same block as the brown (or blue) ding ding box. http://pages.prodigy.net/gearhead43/DavesGP/images/dic1.jpg See the brown box next to the C200? That's the hazard flasher right under it (The silver cylender) Quote
