conley3.1 Posted February 27, 2004 Report Posted February 27, 2004 What's the size of the main hub bolt (the big one) on a 92 wbody with 3.1? Quote
Robby1870 Posted February 27, 2004 Report Posted February 27, 2004 36mm (Im pretty sure on that) Quote
mfewtrail Posted February 27, 2004 Report Posted February 27, 2004 36mm (Im pretty sure on that) I also think it's a 36mm, I posted this earlier in this thread but I hit "delete" instead of edit when I wanted to edit the post :oops: Quote
92turboLE Posted February 27, 2004 Report Posted February 27, 2004 36, and if it hasnt been taken off anytime recently good luck getting that fucker off... i used a 6 ft. breaker bar and couldnt break it loose. I had to use a 240 ft/lb impact and that even took a good 20-30 minutes constant to get it out. then if your pulling the axel you will need a hook type pulley remover. - Justin Quote
GnatGoSplat Posted February 27, 2004 Report Posted February 27, 2004 I may have missed it... what was the size of the hub nut again? Quote
conley3.1 Posted February 27, 2004 Author Report Posted February 27, 2004 thanks everyone. I tried a forum search, but it didn't find anything Quote
Robby1870 Posted February 27, 2004 Report Posted February 27, 2004 36, and if it hasnt been taken off anytime recently good luck getting that fucker off... i used a 6 ft. breaker bar and couldnt break it loose. I had to use a 240 ft/lb impact and that even took a good 20-30 minutes constant to get it out. then if your pulling the axel you will need a hook type pulley remover. - Justin I used a 3/4" drive impact wrench to get mine off the first time. It was neat watching it turn like 1/4 turn a sec. Quote
conley3.1 Posted February 29, 2004 Author Report Posted February 29, 2004 Well, as soon as this damn snow stops and it freaking warms up, i'll get to work... Damn its cold Quote
GnatGoSplat Posted February 29, 2004 Report Posted February 29, 2004 I just pulled the hub nut off my 89 with my $20 Harbor Freight 12V impact wrench. Worked great aside from taking 2 minutes to get it completely off! Quote
