got me a T3!!
Welllll, one would think if would exhale better out the exhaust since its a T3 BUT, if the turbo was sized for a 2.2 liter motor, maybe not, thing is there are many types and sizes of T3's, some pretty small and some larger, with the largest being somewhere around 300 hp I think (been a while since I looked), I think the other post you did on this same topic got you info to that effect being quite a few sizes and hp versions, the T25 is stated as a turbo for a engine in the 2.2 to 2.4L range, and about 240 to 260 hp max, not sure what this one is "max" as I belive that quote was what it was doing with the 2.2L engine stock.
Hope it works out!
Jeff M
Guest TurboSedan
I figured I'd better buy a new turbo when I ringed a bolt off in the turbine housing trying to get the downpipe off.
marcus
i have sort of the same deal with one of my TGP turbos. it has absolutely NO shaft play whatsoever, but one of the crossover bolt holes is stripped out and there is some slight galling on the crossover flange itself. i would like to find a good exhaust turbine housing for it, but haven't found one. i did find one on ebay a while back but was outbid :( whoever used it before actually had a nut and a longer bolt to 'fix' the problem.
i scored the turbo/pipe for $35 tho along with the crossover pipe, from someone on the turbododge.com forum of all places :) have you tried extracting the broken bolt from your turbo yet?
joshua
from a pre '90 Saab 16 valve 900. it's .42 a/r. he said it's pretty much the same as whats on a turbo II dodge.
I figure I'm going to get a hybrid kit to make the compressor a t4 down the road. or I'll just upgrade to a super 60 wheel.
I looked at my turbo turbine then looked at the pictures and the new one will definitly flow better exhaust.
marcus
I hope it came from at least an 88 Saab. 87 and older Saabs didn't use water-cooled turbos.
Granted, a non-watercooled turbo would be easier to install, but won't last as long.
I'll make a flange. It's water cooled.
he said all the info o nteh site was correct except what car it was from.
I'm trying to find out how much if any is it better.
I know the exhaust should flow better but the intake side might be real close to the T25. if it is I'll just get an upgraded wheel.
marcus
marcus
Sounds like a good plan. Here is some fun but also to give an idea on how many common Garrett Turbos there are, there are others (ours is not listed), but its humbling to see how many turbos/different setups have been done for different engines. Though this list takes up less space than a pic or such, I will probably take it off after everyone gets a laugh :lol:
Jeff M
Part # Description Model MSRP
144400-0000 TURBOCHARGER (NEW) HT3B $687.50
144401-0000 TURBOCHARGER (NEW) HT3B $687.50
144402-0000 TURBOCHARGER (NEW) HT3B $687.50
144403-0000 TURBOCHARGER (NEW) HT3B $687.50
144404-0000 TURBOCHARGER (NEW) HT3B $687.50
144405-0000 TURBOCHARGER (NEW) HT3B $687.50
144407-0000 TURBOCHARGER (NEW) HT3B $687.50
144408-0000 TURBOCHARGER (NEW) HT3B $687.50
144409-0000 TURBOCHARGER (NEW) HT3B $687.50
144700-0000 TURBOCHARGER (NEW) BHT3B $750.00
144701-0000 TURBOCHARGER (NEW) BHT3B $750.00
144702-0000 TURBOCHARGER (NEW) BHT3B $750.00
144704-0000 TURBOCHARGER (NEW) BHT3B $750.00
144800-0000 TURBOCHARGER (NEW) BHT3 $687.50
402910-5032S TURBOCHARGER (NEW) T1810 $3,250.00
402910-9032S TURBOCHARGER (REMANUFACTURED) T1810 $2,500.00
405490-5016S TURBOCHARGER (NEW) T1210 $2,000.00
405490-5020S TURBOCHARGER (NEW) T1210 $2,000.00
407370-5008S TURBOCHARGER (NEW) T18A40 $1,412.50
407370-5009S TURBOCHARGER (NEW) T18A40 $1,412.50
407370-5010S TURBOCHARGER (NEW) T18A40 $1,412.50
407370-9006S TURBOCHARGER (REMANUFACTURED) T18A40 $1,162.50
407370-9007S TURBOCHARGER (REMANUFACTURED) T18A40 $1,162.50
407370-9008S TURBOCHARGER (REMANUFACTURED) T18A40 $1,162.50
407370-9009S TURBOCHARGER (REMANUFACTURED) T18A40 $1,162.50
407370-9010S TURBOCHARGER (REMANUFACTURED) T18A40 $1,162.50
407620-9002S TURBOCHARGER (REMANUFACTURED) TE0616 $1,150.00
407640-5009S TURBOCHARGER (NEW) T1224 $2,000.00
407640-9009S TURBOCHARGER (REMANUFACTURED) T1224 $1,500.00
408110-5005S TURBOCHARGER (NEW) T1227 $2,000.00
408110-5006S TURBOCHARGER (NEW) T1227 $2,000.00
408110-9006S TURBOCHARGER (REMANUFACTURED) T1227 $1,625.00
408140-5001S TURBOCHARGER (NEW) TH08A30 $1,312.50
408140-9001S TURBOCHARGER (REMANUFACTURED) TH08A30 $1,250.00
408820-5007S TURBOCHARGER (NEW) T18A73 $2,000.00
408820-9007S TURBOCHARGER (REMANUFACTURED) T18A73 $1,900.00
408820-9017S TURBOCHARGER (REMANUFACTURED) T18A73 $1,900.00
408970-9002S TURBOCHARGER (REMANUFACTURED) T04B05 $500.00
409040-5010S TURBOCHARGER (NEW) T04B8 $700.00
409040-9010S TURBOCHARGER (REMANUFACTURED) T04B8 $562.50
409040-9011S TURBOCHARGER (REMANUFACTURED) T04B8 $562.50
409040-9014S TURBOCHARGER (REMANUFACTURED) T04B8 $562.50
409080-5009S TURBOCHARGER (NEW) T04B9 $462.50
409080-9009S TURBOCHARGER (REMANUFACTURED) T04B9 $437.50
409080-9012S TURBOCHARGER (REMANUFACTURED) T04B9 $437.50
409080-9013S TURBOCHARGER (REMANUFACTURED) T04B9 $437.50
409200-9013S TURBOCHARGER (REMANUFACTURED) T04B39 $812.50
409200-9014S TURBOCHARGER (REMANUFACTURED) T04B39 $812.50
409250-5002S TURBOCHARGER (NEW) T04B05 $462.50
409250-9002S TURBOCHARGER (REMANUFACTURED) T04B05 $437.50
409280-5001S TURBOCHARGER (NEW) TH08A30 $2,250.00
409280-9001S TURBOCHARGER (REMANUFACTURED) TH08A30 $1,875.00
409280-9002S TURBOCHARGER (REMANUFACTURED) TH08A30 $1,875.00
409300-0031 TURBOCHARGER (NEW) T04B05 $525.00
409300-9011S TURBOCHARGER (REMANUFACTURED) T04B27 $750.00
409410-5002S TURBOCHARGER (NEW) T04B91 $687.50
409410-5006S TURBOCHARGER (NEW) T04B91 $687.50
409410-9002S TURBOCHARGER (REMANUFACTURED) T04B91 $562.50
409410-9006S TURBOCHARGER (REMANUFACTURED) T04B91 $562.50
409570-5010S TURBOCHARGER (NEW) T04B18 $462.50
409570-5016S TURBOCHARGER (NEW) T04B18 $462.50
409570-9010S TURBOCHARGER (REMANUFACTURED) T04B18 $437.50
409570-9014S TURBOCHARGER (REMANUFACTURED) T04B18 $437.50
409570-9016S TURBOCHARGER (REMANUFACTURED) T04B18 $437.50
409570-9020S TURBOCHARGER (REMANUFACTURED) T04B18 $437.50
409640-5004S TURBOCHARGER (NEW) T04B19 $462.50
409640-9004S TURBOCHARGER (REMANUFACTURED) T04B19 $437.50
409720-5002S TURBOCHARGER (NEW) T1232 $2,000.00
409720-9002S TURBOCHARGER (REMANUFACTURED) T1232 $1,500.00
409720-9004S TURBOCHARGER (REMANUFACTURED) T1232 $1,500.00
409750-5001S TURBOCHARGER (NEW) T18A90 $1,437.50
409750-5003S TURBOCHARGER (NEW) T18A01 $1,437.50
409750-9001S TURBOCHARGER (REMANUFACTURED) T18A9 $1,312.50
409750-9003S TURBOCHARGER (REMANUFACTURED) T18A9 $1,312.50
409760-9002S TURBOCHARGER (REMANUFACTURED) T04B05 $562.50
409770-5018S TURBOCHARGER (NEW) T04B25 $462.50
409770-5019S TURBOCHARGER (NEW) T04B25 $462.50
409770-5025S TURBOCHARGER (NEW) T04B05 $462.50
409770-9018S TURBOCHARGER (REMANUFACTURED) T04B25 $437.50
409770-9019S TURBOCHARGER (REMANUFACTURED) T04B25 $437.50
409770-9025S TURBOCHARGER (REMANUFACTURED) T04B25 $437.50
409930-5003S TURBOCHARGER (NEW) T04B31 $750.00
409930-9003S TURBOCHARGER (REMANUFACTURED) T04B31 $562.50
409940-9002S TURBOCHARGER (REMANUFACTURED) T04B32 $562.50
409940-9004S TURBOCHARGER (REMANUFACTURED) T04B32 $562.50
409940-9007S TURBOCHARGER (REMANUFACTURED) T04B32 $562.50
452044-0001 TURBOCHARGER (NEW) TB2548 $937.50
452044-5003S TURBOCHARGER (NEW) TB2548 $937.50
452044-5004S TURBOCHARGER (NEW) TB2548 $937.50
452046-0003 TURBOCHARGER (NEW) TBP4 $1,250.00
452046-5002S TURBOCHARGER (NEW) TBP42 $1,250.00
452055-0004 TURBOCHARGER (NEW) T250-4 $875.00
452058-0002 TURBOCHARGER (NEW) TB2556 $875.00
452071-5003S TURBOCHARGER (NEW) TBP412 $1,000.00
452073-0004 TURBOCHARGER (NEW) TB2565 $875.00
452076-0002 TURBOCHARGER (NEW) T04E36 $875.00
452077-0001 TURBOCHARGER (NEW) T04E35 $1,062.50
452077-5003S TURBOCHARGER (NEW) T04E35 $875.00
452077-5004S TURBOCHARGER (NEW) T04E35 $875.00
452077-5007S TURBOCHARGER (NEW) T04E35 $1,062.50
452080-0002 TURBOCHARGER (NEW) TV48-2 $1,562.50
452083-0001 TURBOCHARGER (NEW) TB252 $1,075.00
452085-0005 TURBOCHARGER (NEW) TBP418-1 $800.00
452085-0009 TURBOCHARGER (NEW) TBP4 $712.50
452101-5001S TURBOCHARGER (NEW) GT4288 $1,500.00
452159-5001S TURBOCHARGER (NEW) GT3776 $1,000.00
452159-5003S TURBOCHARGER (NEW) GT3776 $1,000.00
452174-9003S TURBOCHARGER (REMANUFACTURED) GT4288 $1,275.00
452187-5006S TURBOCHARGER (NEW) GT1544 $1,000.00
452195-0001 TURBOCHARGER (NEW) GT1544 $1,125.00
452203-5001S TURBOCHARGER (NEW) T04E35 $1,125.00
452214-5003S TURBOCHARGER (NEW) GT2259 $812.50
452232-5005S TURBOCHARGER (NEW) GT4082 $1,062.50
452233-5002S TURBOCHARGER (NEW) GT3267S $1,125.00
452233-5005S TURBOCHARGER (NEW) GT3267SS $1,000.00
452234-5002S TURBOCHARGER (NEW) GT2052 $875.00
452301-5003S TURBOCHARGER (NEW) GT2052 $1,125.00
454041-0001 TURBOCHARGER (NEW) T300-2 $750.00
454044-5001S TURBOCHARGER (NEW) T300-03 $812.50
454082-0002 TURBOCHARGER (NEW) GT1544 $625.00
454083-0002 TURBOCHARGER (NEW) GT1544 $625.00
454088-0001 TURBOCHARGER (NEW) TB271 $1,000.00
454126-5002S TURBOCHARGER (NEW) GT2056S $875.00
454150-0005 TURBOCHARGER (NEW) VNT2501 $1,250.00
454232-5005S TURBOCHARGER (NEW) GT1749V $1,437.50
465010-5001S TURBOCHARGER (NEW) TV811 $1,362.50
465010-9001S TURBOCHARGER (REMANUFACTURED) TV811 $875.00
465010-9002S TURBOCHARGER (REMANUFACTURED) TV811 $875.00
465020-5002S TURBOCHARGER (NEW) TV812 $1,312.50
465020-9002S TURBOCHARGER (REMANUFACTURED) TV812 $875.00
465030-5004S TURBOCHARGER (REMANUFACTURED) TV711 $1,250.00
465030-9001S TURBOCHARGER (REMANUFACTURED) TV711 $875.00
465030-9004S TURBOCHARGER (REMANUFACTURED) TV711 $875.00
465030-9005S TURBOCHARGER (REMANUFACTURED) TV711 $875.00
465030-9007S TURBOCHARGER (REMANUFACTURED) TV711 $875.00
465032-5001S TURBOCHARGER (NEW) T1238 $2,000.00
465032-9001S TURBOCHARGER (REMANUFACTURED) T1238 $1,312.50
465044-0227 TURBOCHARGER (NEW) T04B59 $750.00
465044-0252 TURBOCHARGER (NEW) T04B59 $750.00
465044-5225S TURBOCHARGER (NEW) T04B59 $750.00
465044-5234S TURBOCHARGER (NEW) T04B59 $750.00
465044-5251S TURBOCHARGER (NEW) T04B59 $750.00
465044-5257S TURBOCHARGER (NEW) T04B59 $750.00
465044-5261S TURBOCHARGER (NEW) T04B59 $750.00
465044-9251S TURBOCHARGER (REMANUFACTURED) T04B59 $625.00
465044-9252S TURBOCHARGER (REMANUFACTURED) T04B59 $625.00
465044-9257S TURBOCHARGER (REMANUFACTURED) T04B59 $625.00
465044-9261S TURBOCHARGER (REMANUFACTURED) T04B59 $625.00
465088-5001S TURBOCHARGER (NEW) T04B65 $1,250.00
465088-9001S TURBOCHARGER (REMANUFACTURED) T04B65 $937.50
465105-5002S TURBOCHARGER (NEW) TA4532 $1,250.00
465105-9002S TURBOCHARGER (REMANUFACTURED) TA4532 $875.00
465115-9002S TURBOCHARGER (REMANUFACTURED) TB368 $900.00
465115-9003S TURBOCHARGER (REMANUFACTURED) TB368 $900.00
465124-5006S TURBOCHARGER (NEW) T04B05 $875.00
465126-5016S TURBOCHARGER (NEW) T18A95 $1,750.00
465126-5019S TURBOCHARGER (NEW) T18A95 $1,750.00
465126-9012S TURBOCHARGER (REMANUFACTURED) T18A95 $1,500.00
465126-9014S TURBOCHARGER (REMANUFACTURED) T18A95 $1,500.00
465126-9016S TURBOCHARGER (REMANUFACTURED) T18A95 $1,500.00
465126-9019S TURBOCHARGER (REMANUFACTURED) T18A95 $1,500.00
465136-9002S TURBOCHARGER (REMANUFACTURED) TV715 $1,500.00
465153-0003 TURBOCHARGER (NEW) T250-1 $750.00
465153-0004 TURBOCHARGER (NEW) T250-1 $750.00
465154-9003S TURBOCHARGER (REMANUFACTURED) T04B71 $687.50
465163-9002S TURBOCHARGER (REMANUFACTURED) TB0382 $1,000.00
465169-0003 TURBOCHARGER (NEW) TB2543 $1,125.00
465181-9002S TURBOCHARGER (REMANUFACTURED) TB2529 $1,125.00
465183-0008 TURBOCHARGER (NEW) TB2531 $1,250.00
465183-9008S TURBOCHARGER (REMANUFACTURED) TB2531 $1,125.00
465184-9002S TURBOCHARGER (REMANUFACTURED) T04B72 $700.00
465193-5113S TURBOCHARGER (NEW) TV9405 $3,500.00
465198-9002S TURBOCHARGER (REMANUFACTURED) T04B74 $625.00
465198-9003S TURBOCHARGER (REMANUFACTURED) T04B74 $625.00
465209-0003 TURBOCHARGER (NEW) T250-5 $750.00
465209-0005 TURBOCHARGER (NEW) T250-01 $750.00
465209-0006 TURBOCHARGER (NEW) T250-01 $750.00
465209-5002S TURBOCHARGER (NEW) T250-05 $750.00
465209-5004S TURBOCHARGER (NEW) T250-05 $750.00
465210-5010S TURBOCHARGER (NEW) T04B35 $812.50
465210-9007S TURBOCHARGER (REMANUFACTURED) T04B05 $625.00
465213-5004S TURBOCHARGER (NEW) TA4536 $687.50
465218-9002S TURBOCHARGER (REMANUFACTURED) T04B9 $625.00
465218-9004S TURBOCHARGER (REMANUFACTURED) T04B9 $625.00
465225-5006S TURBOCHARGER (NEW) T04E17 $875.00
465225-5010S TURBOCHARGER (NEW) T04E17 $875.00
465225-5016S TURBOCHARGER (NEW) T04E17 $875.00
465225-9001S TURBOCHARGER (REMANUFACTURED) T04E17 $750.00
465225-9002S TURBOCHARGER (REMANUFACTURED) T04E17 $750.00
465225-9006S TURBOCHARGER (REMANUFACTURED) T04E17 $750.00
465225-9007S TURBOCHARGER (REMANUFACTURED) T04E17 $750.00
465225-9009S TURBOCHARGER (REMANUFACTURED) T04E17 $750.00
465225-9010S TURBOCHARGER (REMANUFACTURED) T04E17 $750.00
465225-9012S TURBOCHARGER (REMANUFACTURED) T04E17 $750.00
465225-9016S TURBOCHARGER (REMANUFACTURED) T04E17 $750.00
465225-9017S TURBOCHARGER (REMANUFACTURED) T04E17 $750.00
465225-9019S TURBOCHARGER (REMANUFACTURED) T04E17 $750.00
465242-5001S TURBOCHARGER (NEW) T04B98 $875.00
465242-5002S TURBOCHARGER (NEW) T04B98 $875.00
465242-5003S TURBOCHARGER (NEW) T04B98 $875.00
465242-9001S TURBOCHARGER (REMANUFACTURED) T04B98 $750.00
465242-9002S TURBOCHARGER (REMANUFACTURED) T04B98 $750.00
465242-9003S TURBOCHARGER (REMANUFACTURED) T04B98 $750.00
465242-9005S TURBOCHARGER (REMANUFACTURED) T04B98 $750.00
465245-5001S TURBOCHARGER (NEW) TA3124 $812.50
465251-5003S TURBOCHARGER (NEW) TW731 $2,537.50
465260-5002S TURBOCHARGER (NEW) T04B37 $462.50
465260-5003S TURBOCHARGER (NEW) T04B37 $462.50
465260-9002S TURBOCHARGER (REMANUFACTURED) T04B37 $437.50
465260-9003S TURBOCHARGER (REMANUFACTURED) T04B37 $437.50
465269-5002S TURBOCHARGER (NEW) TB4133 $1,000.00
465282-5007S TURBOCHARGER (NEW) T18A96 $3,000.00
465282-9001S TURBOCHARGER (REMANUFACTURED) T18A96 $2,500.00
465282-9007S TURBOCHARGER (REMANUFACTURED) T18A96 $2,500.00
465282-9009S TURBOCHARGER (REMANUFACTURED) T18A96 $2,500.00
465288-9003S TURBOCHARGER (REMANUFACTURED) T04B94 $625.00
465300-9001S TURBOCHARGER (REMANUFACTURED) T04B38 $900.00
465320-9001S TURBOCHARGER (REMANUFACTURED) TV612 $1,125.00
465320-9002S TURBOCHARGER (REMANUFACTURED) TV612 $1,125.00
465320-9005S TURBOCHARGER (REMANUFACTURED) TV612 $1,125.00
465320-9006S TURBOCHARGER (REMANUFACTURED) TV612 $1,125.00
465324-5003S TURBOCHARGER (NEW) TV8111 $3,750.00
465329-5004S TURBOCHARGER (NEW) TV946 $2,762.50
465329-9004S TURBOCHARGER (REMANUFACTURED) TV946 $2,125.00
465354-9007S TURBOCHARGER (REMANUFACTURED) TA311 $812.50
465355-5001S TURBOCHARGER (NEW) T04E45 $812.50
465355-9001S TURBOCHARGER (REMANUFACTURED) T04E45 $650.00
465355-9002S TURBOCHARGER (REMANUFACTURED) T04E45 $650.00
465355-9003S TURBOCHARGER (REMANUFACTURED) T04E45 $650.00
465355-9011S TURBOCHARGER (REMANUFACTURED) T04E45 $650.00
465356-9002S TURBOCHARGER (REMANUFACTURED) TV6125 $1,250.00
465360-9002S TURBOCHARGER (REMANUFACTURED) T04B42 $562.50
465360-9013S TURBOCHARGER (REMANUFACTURED) T04B42 $562.50
465366-0018 TURBOCHARGER (NEW) T04B81 $525.00
465366-5013S TURBOCHARGER (NEW) T04B81 $887.50
465366-9018S TURBOCHARGER (REMANUFACTURED) T04B81 $475.00
465369-5003S TURBOCHARGER (NEW) TV7512 $1,750.00
465369-5004S TURBOCHARGER (NEW) TV7512 $1,750.00
465369-5007S TURBOCHARGER (NEW) TV7512 $1,750.00
465369-5008S TURBOCHARGER (NEW) TV7512 $1,750.00
465369-9001S TURBOCHARGER (REMANUFACTURED) TV7512 $1,312.50
465369-9002S TURBOCHARGER (REMANUFACTURED) TV7512 $1,312.50
465369-9003S TURBOCHARGER (REMANUFACTURED) TV7512 $1,312.50
465369-9004S TURBOCHARGER (REMANUFACTURED) TV7512 $1,312.50
465369-9005S TURBOCHARGER (REMANUFACTURED) TV7512 $1,312.50
465369-9007S TURBOCHARGER (REMANUFACTURED) TV7512 $1,312.50
465369-9008S TURBOCHARGER (REMANUFACTURED) TV7512 $1,312.50
465380-5033 TURBOCHARGER (NEW) TV6102 $750.00
465380-9014S TURBOCHARGER (REMANUFACTURED) TV613 $687.50
465408-9001S TURBOCHARGER (REMANUFACTURED) TV6123 $1,125.00
465424-9001S TURBOCHARGER (REMANUFACTURED) T04B8 $687.50
465424-9002S TURBOCHARGER (REMANUFACTURED) T04B8 $687.50
465438-5002S TURBOCHARGER (NEW) TV7111 $1,375.00
465438-5005S TURBOCHARGER (NEW) TV7111 $1,375.00
465438-9002S TURBOCHARGER (REMANUFACTURED) TV7111 $1,125.00
465438-9005S TURBOCHARGER (REMANUFACTURED) TV7111 $1,125.00
465458-5001S TURBOCHARGER (NEW) TW181 $4,500.00
465468-9008S TURBOCHARGER (REMANUFACTURED) T04B5 $750.00
465476-9002S TURBOCHARGER (REMANUFACTURED) T04B83 $875.00
465496-9001S TURBOCHARGER (REMANUFACTURED) TV6141 $1,000.00
465498-5002S TURBOCHARGER (NEW) TV7701 $1,500.00
465498-9002S TURBOCHARGER (REMANUFACTURED) TV771 $1,187.50
465498-9007S TURBOCHARGER (REMANUFACTURED) TV771 $1,187.50
465506-9001S TURBOCHARGER (REMANUFACTURED) TA312 $812.50
465540-5001S TURBOCHARGER (NEW) T1235 $2,000.00
465540-9001S TURBOCHARGER (REMANUFACTURED) T1235 $1,500.00
465574-9001S TURBOCHARGER (REMANUFACTURED) T18A85 $1,625.00
465588-5001S TURBOCHARGER (NEW) TW6138 $2,000.00
465590-5005S TURBOCHARGER (NEW) T04B45 $1,000.00
465593-5004S TURBOCHARGER (NEW) TA3401 $712.50
465593-9001S TURBOCHARGER (REMANUFACTURED) TA344 $587.50
465593-9004S TURBOCHARGER (REMANUFACTURED) TA344 $587.50
465593-9005S TURBOCHARGER (REMANUFACTURED) TA344 $587.50
465593-9009S TURBOCHARGER (REMANUFACTURED) TA344 $587.50
465600-9003S TURBOCHARGER (REMANUFACTURED) T04B46 $812.50
465629-0002 TURBOCHARGER (NEW) T04E43 $1,000.00
465636-0216 TURBOCHARGER (NEW) TA313 $1,250.00
465636-9001S TURBOCHARGER (REMANUFACTURED) TA31 $1,000.00
465636-9002S TURBOCHARGER (REMANUFACTURED) TA31 $1,000.00
465636-9207S TURBOCHARGER (REMANUFACTURED) TA313 $1,000.00
465637-9001S TURBOCHARGER (REMANUFACTURED) T04E48 $687.50
465640-5021S TURBOCHARGER (NEW) T04B49 $1,187.50
465695-5001S TURBOCHARGER (NEW) TMF5101 $1,437.50
465695-9001S TURBOCHARGER (REMANUFACTURED) TMF511 $687.50
465715-9001S TURBOCHARGER (REMANUFACTURED) TA4535 $1,400.00
465716-9001S TURBOCHARGER (REMANUFACTURED) TV8116 $1,437.50
465716-9002S TURBOCHARGER (REMANUFACTURED) TV8116 $1,437.50
465717-9001S TURBOCHARGER (REMANUFACTURED) TW941 $2,250.00
465740-9001S TURBOCHARGER (REMANUFACTURED) T04B51 $625.00
465740-9003S TURBOCHARGER (REMANUFACTURED) T04B51 $625.00
465745-5002S TURBOCHARGER (NEW) TV8513 $1,650.00
465745-9001S TURBOCHARGER (REMANUFACTURED) TV8513 $1,312.50
465745-9002S TURBOCHARGER (REMANUFACTURED) TV8513 $1,312.50
465745-9004S TURBOCHARGER (REMANUFACTURED) TV8513 $1,312.50
465752-9001S TURBOCHARGER (REMANUFACTURED) TA318 $1,000.00
465776-0008 TURBOCHARGER (NEW) TA316 $1,000.00
465778-0016 TURBOCHARGER (NEW) TA31 $1,000.00
465778-0017 TURBOCHARGER (NEW) TA3107 $1,000.00
465778-0018 TURBOCHARGER (NEW) TA3107 $1,000.00
465778-9002S TURBOCHARGER (REMANUFACTURED) TA3107 $812.50
465778-9004S TURBOCHARGER (REMANUFACTURED) TA3107 $812.50
465795-0004 TURBOCHARGER (NEW) TB2525 $1,000.00
465823-5002S TURBOCHARGER (NEW) GT4594 $1,000.00
465861-5002S TURBOCHARGER (NEW) TT5501 $1,000.00
465861-5003S TURBOCHARGER (NEW) TT552 $1,000.00
465890-9001S TURBOCHARGER (REMANUFACTURED) T1204 $1,375.00
465896-0002 TURBOCHARGER (NEW) TA3112 $1,062.50
465904-9002S TURBOCHARGER (REMANUFACTURED) TB321 $1,062.50
465907-9001S TURBOCHARGER (REMANUFACTURED) T04E19 $875.00
465922-5011S TURBOCHARGER (NEW) TA452 $1,125.00
465934-0002 TURBOCHARGER (NEW) T18A87 $2,500.00
465939-5002S TURBOCHARGER (NEW) TB2528 $1,125.00
465939-9002S TURBOCHARGER (REMANUFACTURED) TB2528 $1,037.50
465945-5001S TURBOCHARGER (NEW) TV843 $1,875.00
465945-9001S TURBOCHARGER (REMANUFACTURED) TV8403 $1,687.50
465945-9002S TURBOCHARGER (REMANUFACTURED) TV843 $1,687.50
465945-9003S TURBOCHARGER (REMANUFACTURED) TV843 $1,687.50
465953-9004S TURBOCHARGER (REMANUFACTURED) TV741 $1,250.00
465958-9007S TURBOCHARGER (REMANUFACTURED) TB4111 $750.00
465960-5003S TURBOCHARGER (NEW) T04B58 $625.00
465981-0002 TURBOCHARGER (NEW) TB4137 $1,125.00
465987-5001S TURBOCHARGER (NEW) TW732 $2,587.50
465987-9001S TURBOCHARGER (REMANUFACTURED) TW732 $2,087.50
465987-9002S TURBOCHARGER (REMANUFACTURED) TW732 $2,087.50
465997-0004 TURBOCHARGER (NEW) TB284 $1,000.00
466003-9002S TURBOCHARGER (REMANUFACTURED) T300 $750.00
466003-9004S TURBOCHARGER (REMANUFACTURED) T300-1 $750.00
466007-5002S TURBOCHARGER (NEW) T350-1 $1,000.00
466007-9002S TURBOCHARGER (REMANUFACTURED) T350-1 $875.00
466007-9008S TURBOCHARGER (REMANUFACTURED) T350 $875.00
466007-9011S TURBOCHARGER (REMANUFACTURED) T350-1 $875.00
466013-9001S TURBOCHARGER (REMANUFACTURED) TB4138 $625.00
466032-9002S TURBOCHARGER (REMANUFACTURED) TB326 $875.00
466035-5002S TURBOCHARGER (NEW) TV947 $3,000.00
466035-5003S TURBOCHARGER (NEW) TV9402 $3,000.00
466038-9001S TURBOCHARGER (REMANUFACTURED) TV8117 $1,125.00
466065-5003S TURBOCHARGER (NEW) T04S04 $1,312.50
466065-9003S TURBOCHARGER (REMANUFACTURED) T04S04 $1,125.00
466073-0008 TURBOCHARGER (NEW) TB229 $875.00
466076-0012 TURBOCHARGER (NEW) TA512 $875.00
466076-5018S TURBOCHARGER (NEW) TA5102 $875.00
466089-0004 TURBOCHARGER (NEW) TB283 $1,000.00
466094-9001S TURBOCHARGER (REMANUFACTURED) TV8121 $1,500.00
466094-9002S TURBOCHARGER (REMANUFACTURED) TV8121 $1,500.00
466125-5001S TURBOCHARGER (NEW) TV7125 $2,000.00
466135-0005 TURBOCHARGER (NEW) TB221 $1,375.00
466154-0025 TURBOCHARGER (NEW) TA5127-4 $1,125.00
466154-5015S TURBOCHARGER (NEW) TA5127-4 $725.00
466159-5003S TURBOCHARGER (NEW) TA3401 $812.50
466159-5004S TURBOCHARGER (NEW) TA3401 $812.50
466159-5005S TURBOCHARGER (NEW) TA3401 $812.50
466159-5008S TURBOCHARGER (NEW) TA3401 $812.50
466159-5010S TURBOCHARGER (NEW) TA3401 $812.50
466163-9011S TURBOCHARGER (REMANUFACTURED) TP3801 $1,000.00
466176-9001S TURBOCHARGER (REMANUFACTURED) TV731 $1,062.50
466176-9005S TURBOCHARGER (REMANUFACTURED) TV731 $1,062.50
466178-9001S TURBOCHARGER (REMANUFACTURED) TV831 $1,062.50
466185-0005 TURBOCHARGER (NEW) TB342 $1,062.50
466186-9005S TURBOCHARGER (REMANUFACTURED) TV841 $1,187.50
466192-5014S TURBOCHARGER (NEW) TA3164 $975.00
466201-9001S TURBOCHARGER (REMANUFACTURED) TA381 $812.50
466201-9002S TURBOCHARGER (REMANUFACTURED) TA3801 $812.50
466203-9001S TURBOCHARGER (REMANUFACTURED) TA382 $1,000.00
466204-9001S TURBOCHARGER (REMANUFACTURED) TB25 $750.00
466229-0001 TURBOCHARGER (NEW) TBP44 $1,000.00
466229-9001S TURBOCHARGER (REMANUFACTURED) TBP44 $875.00
466245-5001S TURBOCHARGER (NEW) TV4501 $1,280.00
466245-9001S TURBOCHARGER (REMANUFACTURED) TV451 $687.50
466258-0001 TURBOCHARGER (NEW) TW511 $2,875.00
466272-9002S TURBOCHARGER (REMANUFACTURED) TB02 $812.50
466290-5001S TURBOCHARGER (NEW) T04E14 $1,000.00
466290-5016S TURBOCHARGER (NEW) T04E14 $1,000.00
466290-5018S TURBOCHARGER (NEW) T04E14 $1,000.00
466290-9001S TURBOCHARGER (REMANUFACTURED) T04E14 $812.50
466290-9002S TURBOCHARGER (REMANUFACTURED) T04E14 $812.50
466290-9008S TURBOCHARGER (REMANUFACTURED) T04E14 $812.50
466290-9009S TURBOCHARGER (REMANUFACTURED) T04E14 $812.50
466290-9016S TURBOCHARGER (REMANUFACTURED) T04E14 $812.50
466290-9017S TURBOCHARGER (REMANUFACTURED) T04E14 $812.50
466298-9004S TURBOCHARGER (REMANUFACTURED) TB335 $812.50
466298-9005S TURBOCHARGER (REMANUFACTURED) TB335 $812.50
466298-9007S TURBOCHARGER (REMANUFACTURED) TB335 $812.50
466314-0004 TURBOCHARGER (NEW) TA45 $1,375.00
466324-5002S TURBOCHARGER (NEW) T04E03 $875.00
466324-9002S TURBOCHARGER (REMANUFACTURED) T04E03 $687.50
466326-5002S TURBOCHARGER (NEW) T04E02 $812.50
466326-9002S TURBOCHARGER (REMANUFACTURED) T04E02 $687.50
466334-5004S TURBOCHARGER (NEW) TA341 $687.50
466334-9004S TURBOCHARGER (REMANUFACTURED) TA341 $587.50
466334-9005S TURBOCHARGER (REMANUFACTURED) TA341 $587.50
466334-9006S TURBOCHARGER (REMANUFACTURED) TA341 $587.50
466334-9010S TURBOCHARGER (REMANUFACTURED) TA341 $587.50
466334-9016S TURBOCHARGER (REMANUFACTURED) TA341 $587.50
466334-9017S TURBOCHARGER (REMANUFACTURED) TA341 $587.50
466334-9018S TURBOCHARGER (REMANUFACTURED) TA3401 $587.50
466348-5002S TURBOCHARGER (NEW) TV632 $1,750.00
466360-5002S TURBOCHARGER (NEW) TV732 $1,500.00
466387-9001S TURBOCHARGER (REMANUFACTURED) TV845 $1,687.50
466398-5003S TURBOCHARGER (NEW) TB4501 $1,187.50
466398-5016S TURBOCHARGER (NEW) TB451 $1,187.50
466398-9016S TURBOCHARGER (REMANUFACTURED) TB451 $937.50
466409-9002S TURBOCHARGER (REMANUFACTURED) TB2502 $812.50
466414-9002S TURBOCHARGER (REMANUFACTURED) TB02 $750.00
466420-9002S TURBOCHARGER (REMANUFACTURED) TB339 $937.50
466456-9001S TURBOCHARGER (REMANUFACTURED) TB343 $1,000.00
466457-9002S TURBOCHARGER (REMANUFACTURED) TC433 $875.00
466478-0012 TURBOCHARGER (NEW) TA514 $750.00
466491-0005 TURBOCHARGER (NEW) TB2566 $1,375.00
466491-0006 TURBOCHARGER (NEW) TB2566 $1,375.00
466498-5004S TURBOCHARGER (NEW) TV752 $1,375.00
466498-9003S TURBOCHARGER (REMANUFACTURED) TV752 $1,062.50
466498-9004S TURBOCHARGER (REMANUFACTURED) TV752 $1,062.50
466515-9003S TURBOCHARGER (REMANUFACTURED) TBP4 $1,250.00
466533-5001S TURBOCHARGER (NEW) TC435 $1,062.50
466533-9001S TURBOCHARGER (REMANUFACTURED) TC435 $937.50
466541-0001 TURBOCHARGER (NEW) TBB25 $1,250.00
466563-5003S TURBOCHARGER (NEW) TA346 $750.00
466563-9003S TURBOCHARGER (REMANUFACTURED) TA346 $625.00
466567-9001S TURBOCHARGER (REMANUFACTURED) T04E $800.00
466569-0001 TURBOCHARGER (NEW) TA5131 $1,375.00
466570-9001S TURBOCHARGER (REMANUFACTURED) TV8511 $1,187.50
466572-5001S TURBOCHARGER (NEW) TV7511 $1,500.00
466572-5004S TURBOCHARGER (NEW) TV7511 $1,500.00
466572-9001S TURBOCHARGER (REMANUFACTURED) TV7511 $1,125.00
466572-9002S TURBOCHARGER (REMANUFACTURED) TV7511 $1,125.00
466572-9003S TURBOCHARGER (REMANUFACTURED) TV7511 $1,125.00
466573-9001S TURBOCHARGER (REMANUFACTURED) TB4142 $875.00
466575-9001S TURBOCHARGER (REMANUFACTURED) TA348 $625.00
466575-9002S TURBOCHARGER (REMANUFACTURED) TA348 $625.00
466588-0001 TURBOCHARGER (NEW) T04E04 $812.50
466588-5003S TURBOCHARGER (NEW) TO4E $812.50
466608-5001S TURBOCHARGER (NEW) TB4129 $462.50
466608-5002S TURBOCHARGER (NEW) TB4129 $462.50
466608-5003S TURBOCHARGER (NEW) TB4129 $462.50
466608-5005S TURBOCHARGER (NEW) TB4129 $625.00
466608-9002S TURBOCHARGER (REMANUFACTURED) TB4129 $437.50
466608-9003S TURBOCHARGER (REMANUFACTURED) TB4129 $437.50
466608-9005S TURBOCHARGER (REMANUFACTURED) TB4129 $562.50
466616-0003 TURBOCHARGER (NEW) T04E06 $1,000.00
466618-0017 TURBOCHARGER (NEW) TA4521-1 $937.50
466629-9002S TURBOCHARGER (REMANUFACTURED) T350 $800.00
466646-5007S TURBOCHARGER (NEW) T04E66-2 $812.50
466646-5011S TURBOCHARGER (NEW) T04E66-3 $812.50
466646-5022S TURBOCHARGER (NEW) T04E66-5 $812.50
466646-5041S TURBOCHARGER (NEW) T04E66 $812.50
466655-5001S TURBOCHARGER (NEW) TV731 $1,762.50
466662-5006S TURBOCHARGER (NEW) TV724 $1,750.00
466662-9004S TURBOCHARGER (REMANUFACTURED) TV724 $1,562.50
466667-5001S TURBOCHARGER (NEW) T04E $1,875.00
466672-9002S TURBOCHARGER (REMANUFACTURED) TB363 $900.00
466674-0003 TURBOCHARGER (NEW) TA3123 $900.00
466674-0004 TURBOCHARGER (NEW) TA3123 $900.00
466702-9001S TURBOCHARGER (REMANUFACTURED) TB413 $687.50
466704-0203 TURBOCHARGER (NEW) T04E08 $937.50
466704-0211 TURBOCHARGER (NEW) T04E08 $937.50
466704-0213 TURBOCHARGER (NEW) T04E08 $937.50
466707-9002S TURBOCHARGER (REMANUFACTURED) BTV75 $1,587.50
466713-5001S TURBOCHARGER (NEW) TMF55 $900.00
466713-5005S TURBOCHARGER (NEW) TMF55 $1,437.50
466713-9001S TURBOCHARGER (REMANUFACTURED) TMF552 $812.50
466713-9002S TURBOCHARGER (REMANUFACTURED) TMF552 $812.50
466713-9005S TURBOCHARGER (REMANUFACTURED) TMF552 $812.50
466742-0003 TURBOCHARGER (NEW) T04E01 $937.50
466742-0006 TURBOCHARGER (NEW) T04E01 $937.50
466742-0012 TURBOCHARGER (NEW) T04E01 $937.50
466742-0013 TURBOCHARGER (NEW) T04E01 $937.50
466746-5010S TURBOCHARGER (NEW) TA31 $650.00
466746-9001S TURBOCHARGER (REMANUFACTURED) TA3119 $750.00
466746-9003S TURBOCHARGER (REMANUFACTURED) TA3119 $750.00
466755-5003S TURBOCHARGER (NEW) GT15 $750.00
466772-5001S TURBOCHARGER (NEW) T04E13 $875.00
466772-9001S TURBOCHARGER (REMANUFACTURED) T04E13 $750.00
466772-9002S TURBOCHARGER (REMANUFACTURED) T04E13 $750.00
466772-9004S TURBOCHARGER (REMANUFACTURED) T04E13 $750.00
466772-9006S TURBOCHARGER (REMANUFACTURED) T04E13 $750.00
466778-0008 TURBOCHARGER (NEW) TA315 $937.50
466800-0005 TURBOCHARGER (NEW) TB35 $937.50
466820-0004 TURBOCHARGER (NEW) T04E12 $1,000.00
466820-9003S TURBOCHARGER (REMANUFACTURED) T04E12 $1,000.00
466820-9006S TURBOCHARGER (REMANUFACTURED) T04E12 $1,000.00
466820-9008S TURBOCHARGER (REMANUFACTURED) T04E12 $1,000.00
466820-9010S TURBOCHARGER (REMANUFACTURED) T04E12 $1,000.00
466828-0001 TURBOCHARGER (NEW) TB4131 $812.50
466828-0007 TURBOCHARGER (NEW) TB4131 $812.50
466828-9001S TURBOCHARGER (REMANUFACTURED) TB4131 $687.50
466838-5003S TURBOCHARGER (NEW) TV5101 $1,000.00
466838-5004S TURBOCHARGER (NEW) TV5101 $1,087.50
466838-9003S TURBOCHARGER (REMANUFACTURED) TV511 $687.50
466838-9004S TURBOCHARGER (REMANUFACTURED) TV511 $687.50
466854-0001 TURBOCHARGER (NEW) TA312 $625.00
466860-0005 TURBOCHARGER (NEW) TA518 $2,000.00
466874-0005 TURBOCHARGER (NEW) TA251 $625.00
466876-9001S TURBOCHARGER (REMANUFACTURED) TB256 $812.50
466882-0003 TURBOCHARGER (NEW) TA5101 $1,400.00
466898-9006S TURBOCHARGER (REMANUFACTURED) TB2502 $812.50
466898-9007S TURBOCHARGER (REMANUFACTURED) TB2502 $812.50
466904-9001S TURBOCHARGER (REMANUFACTURED) TB4132 $1,037.50
466904-9002S TURBOCHARGER (REMANUFACTURED) TB4132 $1,037.50
466904-9004S TURBOCHARGER (REMANUFACTURED) TB4132 $1,037.50
466904-9005S TURBOCHARGER (REMANUFACTURED) TB4132 $1,037.50
466923-9003S TURBOCHARGER (REMANUFACTURED) TMF553 $1,000.00
466923-9004S TURBOCHARGER (REMANUFACTURED) TMF55 $1,000.00
466923-9006S TURBOCHARGER (REMANUFACTURED) TMF55 $1,000.00
466923-9007S TURBOCHARGER (REMANUFACTURED) TMF55 $1,000.00
466926-5001S TURBOCHARGER (NEW) TW831 $2,512.50
466932-9002S TURBOCHARGER (REMANUFACTURED) TA3122 $800.00
466937-9002S TURBOCHARGER (REMANUFACTURED) GT3571 $2,625.00
466950-0002 TURBOCHARGER (NEW) TA4516 $1,000.00
466950-0004 TURBOCHARGER (NEW) TA4516 $1,000.00
466973-9003S TURBOCHARGER (REMANUFACTURED) TV4501 $1,150.00
466973-9005S TURBOCHARGER (REMANUFACTURED) TV4501 $1,150.00
466980-9001S TURBOCHARGER (REMANUFACTURED) TA343 $562.50
466998-5001S TURBOCHARGER (NEW) TV4501 $1,175.00
466998-5006S TURBOCHARGER (NEW) TV4501 $1,175.00
466998-9001S TURBOCHARGER (REMANUFACTURED) TV452 $687.50
466998-9006S TURBOCHARGER (REMANUFACTURED) TV452 $687.50
466999-5001S TURBOCHARGER (NEW) TMF5101 $750.00
466999-9001S TURBOCHARGER (REMANUFACTURED) TMF512 $687.50
467600-9001S TURBOCHARGER (REMANUFACTURED) TBP403 $2,000.00
468485-9004S KIT,TURBOCHARGER TP3801 $825.00
471037-0002 TURBOCHARGER (NEW) TB2559 $1,187.50
471049-5002S TURBOCHARGER (NEW) T300-08 $775.00
471049-5004S TURBOCHARGER (NEW) T300 $775.00
471049-9001S TURBOCHARGER (REMANUFACTURED) T300-8 $650.00
471049-9004S TURBOCHARGER (REMANUFACTURED) T300 $650.00
471050-5001S TURBOCHARGER (NEW) T350 $1,000.00
471050-5004S TURBOCHARGER (NEW) T350 $1,000.00
471050-5009S TURBOCHARGER (NEW) T350 $1,000.00
471050-5025S TURBOCHARGER (NEW) T350 $1,000.00
471050-9001S TURBOCHARGER (REMANUFACTURED) T350 $875.00
471050-9004S TURBOCHARGER (REMANUFACTURED) T350 $875.00
471050-9005S TURBOCHARGER (REMANUFACTURED) T350 $875.00
471050-9011S TURBOCHARGER (REMANUFACTURED) T350-4 $875.00
471050-9020S TURBOCHARGER (REMANUFACTURED) T350 $875.00
471084-9006S TURBOCHARGER (REMANUFACTURED) BTV75 $2,000.00
471084-9007S TURBOCHARGER (REMANUFACTURED) BTV75 $2,000.00
471085-9005S TURBOCHARGER (REMANUFACTURED) BTV8501 $2,000.00
471085-9006S TURBOCHARGER (REMANUFACTURED) BTV8501 $2,000.00
471171-0003 TURBOCHARGER (NEW) TBB2501 $1,250.00
471187-9002S TURBOCHARGER (REMANUFACTURED) TMF55 $2,000.00
479009-9002S TURBOCHARGER (REMANUFACTURED) T04E59 $1,625.00
479040-9001S TURBOCHARGER (REMANUFACTURED) T04E68 $937.50
479045-5001S TURBOCHARGER (NEW) TBP436 $1,062.50
479046-5001S TURBOCHARGER (NEW) T04E69 $1,062.50
700382-5012S TURBOCHARGER (NEW) GT30BB $1,375.00
700415-9001S TURBOCHARGER (REMANUFACTURED) GT3571 $1,000.00
700415-9004S TURBOCHARGER (REMANUFACTURED) GT3571 $1,250.00
700415-9006S TURBOCHARGER (REMANUFACTURED) GT3571DFG $1,000.00
700437-9001S TURBOCHARGER (REMANUFACTURED) GT3267 $1,500.00
700716-9006S TURBOCHARGER (REMANUFACTURED) GT40 $812.50
701100-5007S TURBOCHARGER (NEW) UTV9406 $3,000.00
701100-5009S TURBOCHARGER (NEW) UTV9406 $3,000.00
701281-9003S TURBOCHARGER (REMANUFACTURED) GT3576D $1,500.00
702154-5001S TURBOCHARGER (NEW) T04E $812.50
702154-5004S TURBOCHARGER (NEW) T04E $812.50
702173-0001 TURBOCHARGER (NEW) GT4082LS $2,000.00
702173-9001S TURBOCHARGER (REMANUFACTURED) GT4082LS $1,687.50
703457-5002S TURBOCHARGER (NEW) GT4088 $1,125.00
703654-0013 TURBOCHARGER (NEW) ... $3,000.00
703724-0001 TURBOCHARGER (NEW) TA31 $1,125.00
704122-9002S TURBOCHARGER (REMANUFACTURED) GT604101BL $1,500.00
704136-5003S TURBOCHARGER (NEW) GT2252 $1,000.00
704322-9001S TURBOCHARGER (REMANUFACTURED) GT500201 $2,000.00
704837-5002S TURBOCHARGER (NEW) UTV9406 $3,750.00
704837-5003S TURBOCHARGER (NEW) UTV9406 $3,750.00
704837-5004S TURBOCHARGER (NEW) UTV9406 $3,750.00
704837-5005S TURBOCHARGER (NEW) UTV9406 $3,750.00
704837-5006S TURBOCHARGER (NEW) UTV9406 $3,750.00
704837-5008S TURBOCHARGER (NEW) UTV9406 $3,750.00
704837-5009S TURBOCHARGER (NEW) UTV9406 $3,750.00
705055-9002S TURBOCHARGER (REMANUFACTURED) TMF55 $2,000.00
705329-0002 TURBOCHARGER (NEW) GT30BB $1,312.50
705330-0001 TURBOCHARGER (NEW) GT25BB $1,750.00
705330-0002 TURBOCHARGER (NEW) GT25BB $1,750.00
706058-0001 TURBOCHARGER (NEW) T04E $875.00
707160-0005 TURBOCHARGER (NEW) GT2538C $1,875.00
707160-0007 TURBOCHARGER (NEW) GT2538C $1,875.00
707866-9001S TURBOCHARGER (REMANUFACTURED) GT47LC $2,000.00
707866-9002S TURBOCHARGER (REMANUFACTURED) GT47LC $2,000.00
708001-5001S TURBOCHARGER (NEW) GT1238 $750.00
712922-0004 TURBOCHARGER (NEW) GT4594 $1,062.50
713672-0002 TURBOCHARGER (NEW) GT17 $1,412.50
714568-5001S TURBOCHARGER (NEW) GT3571 $2,062.50
714568-5002S TURBOCHARGER (NEW) GT3571 $2,062.50
714785-5003S TURBOCHARGER (NEW) GT4288 $1,450.00
714785-9001S TURBOCHARGER (REMANUFACTURED) GT4294 $1,250.00
714785-9003S TURBOCHARGER (REMANUFACTURED) GT42 $1,250.00
714787-5003S TURBOCHARGER (NEW) GT4288 $2,437.50
714787-5009S TURBOCHARGER (NEW) GT4288 $2,437.50
714787-5013S TURBOCHARGER (NEW) GT4288 $2,437.50
714787-5015S TURBOCHARGER (NEW) GT4288 $2,437.50
714787-5020S TURBOCHARGER (NEW) GT4288 $2,437.50
714787-9001S TURBOCHARGER (REMANUFACTURED) GT4288 $1,625.00
714787-9002S TURBOCHARGER (REMANUFACTURED) GT4288 $1,625.00
714787-9003S TURBOCHARGER (REMANUFACTURED) GT4288 $1,700.00
714787-9009S TURBOCHARGER (REMANUFACTURED) GT4288 $1,625.00
714787-9013S TURBOCHARGER (REMANUFACTURED) GT4288 $1,475.00
714787-9015S TURBOCHARGER (REMANUFACTURED) GT4288 $1,287.50
714787-9018S TURBOCHARGER (REMANUFACTURED) GT4288 $1,625.00
714787-9019S TURBOCHARGER (REMANUFACTURED) GT4288 $1,625.00
714787-9020S TURBOCHARGER (REMANUFACTURED) GT4288 $1,625.00
714788-5001S TURBOCHARGER (NEW) GT4288 $2,000.00
714788-5002S TURBOCHARGER (NEW) GT4288 $2,000.00
714788-5003S TURBOCHARGER (NEW) GT4288 $2,000.00
714788-5005S TURBOCHARGER (NEW) GT4288 $2,000.00
714788-5006S TURBOCHARGER (NEW) GT4288 $2,000.00
714788-9001S TURBOCHARGER (REMANUFACTURED) GT4288 $1,250.00
714788-9002S TURBOCHARGER (REMANUFACTURED) GT4288 $1,475.00
714788-9003S TURBOCHARGER (REMANUFACTURED) GT4288 $1,375.00
714788-9005S TURBOCHARGER (REMANUFACTURED) GT4288 $1,425.00
714788-9006S TURBOCHARGER (REMANUFACTURED) GT4288 $1,600.00
714788-9008S TURBOCHARGER (REMANUFACTURED) GT4288 $1,475.00
714789-5001S TURBOCHARGER (NEW) GT4288 $2,000.00
714789-5002S TURBOCHARGER (NEW) GT4288 $2,000.00
714789-5004S TURBOCHARGER (NEW) GT4288 $2,000.00
714789-5007S TURBOCHARGER (NEW) GT4288 $2,000.00
714789-9001S TURBOCHARGER (REMANUFACTURED) GT4288 $1,500.00
714789-9002S TURBOCHARGER (REMANUFACTURED) GT4288 $1,500.00
714789-9004S TURBOCHARGER (REMANUFACTURED) GT4288 $1,000.00
714789-9007S TURBOCHARGER (REMANUFACTURED) GT4288 $1,700.00
714791-5002S TURBOCHARGER (NEW) GT4288 $2,250.00
714791-9002S TURBOCHARGER (REMANUFACTURED) GT4288 $1,787.50
714792-5002S TURBOCHARGER (NEW) GT4288 $1,500.00
714792-5003S TURBOCHARGER (NEW) GT4288 $2,000.00
714792-9002S TURBOCHARGER (REMANUFACTURED) GT4288 $1,187.50
714792-9003S TURBOCHARGER (REMANUFACTURED) GT4288 $1,412.50
714792-9005S TURBOCHARGER (REMANUFACTURED) GT4288 $1,375.00
714793-5003S TURBOCHARGER (NEW) GT4288 $2,000.00
714793-9003S TURBOCHARGER (REMANUFACTURED) GT4288 $1,512.50
714794-5001S TURBOCHARGER (NEW) GT4288 $2,000.00
714794-9001S TURBOCHARGER (REMANUFACTURED) GT4288 $1,512.50
714795-5001S TURBOCHARGER (NEW) GT4288 $2,500.00
714795-5002S TURBOCHARGER (NEW) GT4288 $2,500.00
714795-5005S TURBOCHARGER (NEW) GT4288 $2,500.00
714795-9001S TURBOCHARGER (REMANUFACTURED) GT4288 $2,250.00
714795-9002S TURBOCHARGER (REMANUFACTURED) GT4288 $2,025.00
714795-9005S TURBOCHARGER (REMANUFACTURED) GT4288 $2,025.00
714796-5002S TURBOCHARGER (NEW) GT4288 $2,500.00
714796-9002S TURBOCHARGER (REMANUFACTURED) GT4288 $2,250.00
714797-5001S TURBOCHARGER (NEW) GT40 $1,625.00
714797-5006S TURBOCHARGER (NEW) GT40 $1,625.00
714797-9001S TURBOCHARGER (REMANUFACTURED) GT40 $1,537.50
714797-9006S TURBOCHARGER (REMANUFACTURED) GT40 $1,537.50
714800-9001S TURBOCHARGER (REMANUFACTURED) GT3576 $3,500.00
715583-5005S TURBOCHARGER (NEW) T04S00 $900.00
715583-5006S TURBOCHARGER (NEW) T04S00 $900.00
715583-5007S TURBOCHARGER (NEW) T04S00 $900.00
715583-5008S TURBOCHARGER (NEW) T04S00 $900.00
721853-5001S TURBOCHARGER (NEW) GT4294 $2,037.50
721853-5003S TURBOCHARGER (NEW) GT4294 $2,037.50
724260-5001S TURBOCHARGER (NEW) T61/71/81 E1 CMP $2,250.00
724260-5002S TURBOCHARGER (NEW) T61/71/81 E1 CMP $2,250.00
724260-5003S TURBOCHARGER (NEW) T61/71/81 E1 CMP $2,250.00
727264-5001S TURBOCHARGER (NEW) GT2052 $750.00
727264-5003S TURBOCHARGER (NEW) GT2052 $1,000.00
727264-5004S TURBOCHARGER (NEW) GT2052 $750.00
727264-5007S TURBOCHARGER (NEW) GT2052 $750.00
731376-5001S TURBOCHARGER (NEW) GT4294 $1,000.00
731376-5002S TURBOCHARGER (NEW) GT4294 $1,000.00
731377-5001S TURBOCHARGER (NEW) GT604101 $5,500.00
731413-5001S TURBOCHARGER (NEW) GT3571
