stlunatics2oo3 Posted February 23, 2004 Report Posted February 23, 2004 okay i need to replace the key lock cylinder cause mine has a problem when i put it to the start postion it will not do anything then i pull back on it and then put it to the start postion it starts and i replaced the starter not to long ago so that can't be the problem so if you kno how to change the key lock cylinder tell me how thanks Jeremy Quote
Dirty Rockstar Posted February 23, 2004 Report Posted February 23, 2004 Well, yta start by taking the plastic trim off from around the column, justy behind the steering wheel, then remove the steering wheel.. Then, the hardware just behind the wheel.. Then, theres a little gold thing with a square in it.. this comes off, then theres a tiny ass screw that you need to access from BEHIND the plate you just pulled that gold thing from.. The screwdriver goes THROUGH that hole.. The screw comes out, then the cylinder just slides out.. Hope you get it out.. If you need more help, let me know, as Ive done it in like 4 cars! Quote
stlunatics2oo3 Posted February 23, 2004 Author Report Posted February 23, 2004 steve was any of them vehicles a w-body okay just checkin lol umm did they have tilt cause the manual says take to dealer cause special tool is needed but if i can get it done with out the tool thats awesome thanks Jeremy Quote
