Wiring Harness Question
Okay, the harness for the tailights hook into a big jumble of wires in the back of the car. The harness isn't the problem. I need to know how to remove the wires from INSIDE the harness. How do you get them out? Sorry if this is a bit vague. I can't get a picture, and I don't know how to describe it any better :? :confused:
Umm you might be able to take out the wires with the terminal ends and swap them around.. I'd have to check on that...... It can be done on harnesses.
slide a very small screwdriver or something of the sort into the harness from the plug side and the wire should pull out relatively easily.
If you take a screw driver the harness should be able to "pop" open and you can pull the wires right out.
