W-Body Rear suspension question
Im having a problem with my rear end sitting too low, about 1 1/2". I was told that it was due to the fiberglass leaf spring has been broken. has anyone else had this problem? and is it only on the cutlasses or is it across the w-body line?
unless you see a crack it's prolly just saggy, my Lumina was low to and I got some Moog K-6000 spring helpers $60 it raised it up and made it stiffer (almost to stiff) springs are around $400 then you have to get them installed $$$ , I'd try this first it maybe all you need.
Mark
My '88 Cutty sits really high in the rear while my sisters '94 sags pretty bad, I
think with most W's its one or the other.
