Memcal
Does anyone know the part # for a memcal from GM? I want to run a custom chip but the old one is soldered in. Thanks!
Here are all the TGP cals that I know of:
Year BCC Scan Id Part Number Release Date Fed/Cal
1989 ASAN8785 8671 16138784 02/24/89 CAL
1989 ASMF0645 0301 16140642 02/24/89 FED
1989 ATMJ5199 5181 16145198 08/11/89 CAL
1989 ATMK5205 5191 16145203 07/31/89 FED
1989 AUAD5199 5181 16148530 10/03/89 CAL
1989 AUAF5205 5191 16148531 07/31/89 FED
1989 AZRC2132 0721 16172131 08/16/91 Not Stated
1990 ASAN8785 8671 16138784 02/24/89 CAL
1990 ASMF0645 0301 16140642 02/24/89 FED
1990 ATMJ5199 5181 16145198 08/11/89 CAL
1990 ATMK5205 5191 16145203 07/31/89 FED
1990 AUAD5199 5181 16148530 10/03/89 CAL
1990 AUAF5205 5191 16148531 07/31/89 FED
1990 AUFR0423 0051 16150422 11/16/89 Not stated
1990 AZRC2132 0721 16172131 08/16/91 Not stated
Scot
Thanks for the replies. I have a topgun chip, but not a memcal. I need the memcal to put my chip in.
How do you have a chip and no MEMCAL? I wasn't aware that Jeff sold the chips w/o MEMCALs. Or did you have someone make a copy for you? Either way, what soldering iron do you plan on using? I can't find one small enough to get in there (for less than $100 that is.)
Well, I bought one from a member on this board. It came w/o the memcal.
Well if you indeed did buy a "chip" w/o a MEMCAL that seems a little odd. (Jay steps away from the keyboard.)
The Chip is a ripped off copy of jeff's chip if it is a Top gun chip. He has never sold one that was not soldered in!!! (Jim steps away from the keyboard.)
Yeah, if it's not soldered in a memcal and it's the eprom only then it's probably a bootleg chip. :cry: :x
Chill out there buddy...The chip was bought from jeff, even he will tell u that...so no, its not some ripped off copy from jeff.
Over 23 chips were used for my car, why would ya need 23 memcals???? Thats why the chip is not in a memcal. because when a new one would come it was just placed in the same memcal, instead of buying a new memcal every time...get it?
The memcal you used, was it originally soldered to a chip?
So, I'm guessing you have a ZIF socket.
That makes sense as it would be a big waste of time to keep soldering in new chip. I have a little adapter that I use so that I never even have to remove the eprom from the memcal, and my UVeraser is an industrial one that I got off of ebay and it can fit over 15 memcals in it!! :shock:
My eraser is software. :wink: Just EEPROM's for me. When I get this WB02 built I will be stacking a 1 meg chip.
Ok, so what is the best way to get this chip in? I can't seem to find a memcal that doesn't already have a chip in it. Should I just try to unsolder and put in? Get an adapter? Something else?
You could do an adapter, but I would (and am) put a ZIF socket in there. That way you can switch the chip as you please, w/ no adapters needed.
