pontiac735 Posted February 20, 2004 Report Posted February 20, 2004 Just wondering if there is a link or help in doing the job,have many people done it? Quote
Guest TurboSedan Posted February 20, 2004 Report Posted February 20, 2004 i have done it. it would be pretty much impossible to do if the engine were in the car. i would do the job with the engine hanging off of a cherry picker because you can't get at it when the engine is on a stand. obviously you'll need to remove the transmission and the flexplate/flywheel. after you get that stuff out of the way it is very easy. carefully pry the old seal out with small flathead screwdriver. thouroughly clean the seal area with Brakleen. lube the outer lip with motor oil and lightly tap the seal into the block evenly with a block of wood and a mallet/hammer. the hard part is getting everything out of the way just so you can get at the rear main seal. it is a 1-piece seal so you won't need to replace the oil pan gasket. if you do the oil pan gasket you will need to do the front timing cover gasket, and if you do that you might as well do the front crank seal in the timing cover while you're at it. joshua Quote
pontiac735 Posted February 20, 2004 Author Report Posted February 20, 2004 Thanks:)I won't be tackling that anytime soon. Quote
Justin Posted February 20, 2004 Report Posted February 20, 2004 Just make sure it's not your dist. O-ring, lots of people think their rear main is leaking when it's really something higher. Quote
pontiac735 Posted February 20, 2004 Author Report Posted February 20, 2004 Yeah I checked that firsrt,pretty dry around there so it must be something else. Quote
PaPaPooh Posted February 20, 2004 Report Posted February 20, 2004 Just make sure it's not your dist. O-ring, lots of people think their rear main is leaking when it's really something higher. did a trans service yesterday and saw oil that looked like the rear main thanks i forgot about the pesky drive seal up top! Quote
regalized Posted February 27, 2004 Report Posted February 27, 2004 where is that dist seal, i am really not sure, i was told mine was leaking but not sure where it is :oops: Quote
SleeperRed90TGp Posted February 27, 2004 Report Posted February 27, 2004 Its not really a dist seal. it's where the dist would go if we had one. it's the oil pump drive located straight down and inboard from the front of the throtle body. It's about 2" round wth a y shaped clamp holding it in. Jud Quote
regalized Posted February 29, 2004 Report Posted February 29, 2004 thanks i know exactly where it is now, just went and looked and oh ya it needs to be replaced, i now know where my oil is going lol i tried to loosen the bolt, 10mm and its on so tight it split the socket, ever happen to anyone else?, i guess i have to go to sears and have them replace it, damn lifetime guarantee , they (craftsman)need it lol Quote
SleeperRed90TGp Posted February 29, 2004 Report Posted February 29, 2004 Get a 6 point socket made for an impat wrench for what ever drive your using. I thought it was 13 mm but it's ben a long time. Little penatrating oil wouldn't hurt either, after all it's been in there 230k miles. Your going to pay plenty to have sears do it. Jud Quote
joey b Posted February 29, 2004 Report Posted February 29, 2004 sears is going to replace the socket Quote
SleeperRed90TGp Posted March 1, 2004 Report Posted March 1, 2004 They should without question. Get a 6 point, there a little stronger. Jud Quote
93CutlassSupreme Posted March 2, 2004 Report Posted March 2, 2004 craftsman sucks! the only reason i buy craftsman is because they're cheap, they have a lifetime warranty, and there's a sears at every street corner almost! their power tools are even worse... Quote
