Guest Anonymous Posted February 18, 2004 Report Posted February 18, 2004 Do I have the heavy duty suspension? Quote
patgizz Posted February 18, 2004 Report Posted February 18, 2004 FE3 SUSPENSION SYSTEM,SPORT hmmm according to that you have: 1991 GP GT white fog lamps grey interior leather wheel + shift knob gauge package sport suspension white 16" wheels and a buncha other stuff i dont feel like looking up Quote
Guest Anonymous Posted February 18, 2004 Report Posted February 18, 2004 1991? That's from my 89 SE. The reason I want to know is I'm getting front struts and all new strut mounts from tirerack. The front strut mounts list a normal and heavy duty suspension. Quote
mfewtrail Posted February 18, 2004 Report Posted February 18, 2004 FE3 SUSPENSION SYSTEM,SPORT hmmm according to that you have: 1991 GP GT white fog lamps grey interior leather wheel + shift knob gauge package sport suspension white 16" wheels and a buncha other stuff i dont feel like looking up The 10th digit in the VIN represents year, so K = 1989 Quote
patgizz Posted February 19, 2004 Report Posted February 19, 2004 ah i was lookin at the wheel code which i guess my source only listed for 91. didnt look at the vin Quote
Gearhead43 Posted February 19, 2004 Report Posted February 19, 2004 RedTurbo - 1989 Pontiac Grand Prix SE VIN Breakdown: 1 - U.S. Built G - GENERAL MOTORS 2 - PONTIAC WP - GRAND PRIX SE 1 - TWO DOOR COUPE 4 - AUTOMATIC BELTS W - 2.8 V6 FI FROM US, CANADA, OR MEXICO 1 - CHECK DIGIT K - MODEL YEAR 1989 F - FAIRFAX KS PLANT 242083 - PRODUCTION SEQ # RPO (Request Production Order) codes located on the Service Parts IDentification label (SPID) breakdown: AAA - EQUIPMENT , STANDARD FOR ABOVE VEHICLES AC3 - ADJUSTOR FRT ST. POWER 6 WAY BKT DRIVER AQ9 - SEAT , FRT BKT PASS DRIVER RECL AR4 - RESTRAINT SYSTEM , "SEAT, AUTO, PASSIVE" AU0 - LOCK CONTROL , REMOTE ENTRY AU3 - LOCK CONTROL , "SIDE DR, ELEC" A31 - WINDOW , "POWER OPERATED, ALL DOORS" A78 - ADJUSTER FRT ST BK , "MANUAL, DRIVER & PASS, RECLINING" A90 - LOCK CONTROL , RR COMPT LID , REM CONT ELEC RELEASE BW2 - MOLDING B/S , DELUXE BW7 - ORNAMENTATION , "EXTR, PLR APLQ" B34 - COVERING FRT , "FLOOR MATS, CARPETED INSERT" B35 - COVERING REAR , "FLOOR MATS, CARPETED INSERT" B4F - PACKAGE , SECURITY LIGHTING B90 - ORNAMENTATION , "EXTR MLDG, SIDE WINDOW REVEAL" B97 - ORNAMENTATION , "EXTR MLDG, LOWER ACCENT" CD4 - WIPER SYSTEM , "WINDSHIELD, PULSE, VARIABLE DELAY" CF5 - ROOF , "SUN, GLASS, SLIDING, ELEC" CR1 - LAMP , INTR FRT DR WARNING C01 - ORNAMENTATION , "EXTR EMBLEM , BODY , VAR 2" C49 - DEFOGGER , "RR WINDOW, ELECTRIC" C67 - HVAC SYSTEM , "AIR CONDITIONER FRT, ELECTRONIC CONTROLS" C96 - LAMP , "INTR, QTR, COURTESY & SINGLE READING" C97 - ILLUMINATED ENTRY DC4 - MIRROR I/S R/V , "TILT, DUAL READING LAMPS" DG7 - MIRROR O/S , "LH & RH, REMOTE CONTROL, ELECTRIC, COLOR" DK4 - CONSOLE , FRT COMPT , MINI OPERATING D55 - CONSOLE , "FRT COMPT, FLOOR" D64 - MIRROR I/S , RH , SUNSHADE , ILLUM E28 - HANDLE ASSIST FAI - PLANT CODE , "FAIRFAX, KS, USA" FE3 - SUSPENSION SYSTEM , SPORT GX3 - RATIO , TRANSAXLE FINAL DRIVE 3.33 ILD - TRIM , INTERIOR DESIGN (LD) J65 - BRAKE SYSTEM , POWER , FRT & RR DISC K34 - CRUISE CONTROL , "AUTOMATIC, ELECTRONIC" K60 - GENERATOR 100 AMP LB6 - ENGINE , 6 CYL, 2.8L, L6, MFI , TRANSVERSE" ME9 - TRANSMISSION , AUTO 4 SPD , THM 44O-T4 MX0 - MERCHANDISED TRANS , "AUTO PROVISIONS, O/D" NA5 - EMISSION SYSTEM , "FEDERAL, TIER 0" NC5 - EXHAUST SYSTEM , DUAL NP5 - STEERING WHEEL , LEATHER WRAPPED NW0 - WHEEL , 16 X 6.5 , CAST ALUMINUM N33 - STEERING COLUMN , TILT TYPE PB4 - LOCK CONTROL , WHEEL QGW - TIRE ALL , P215 / 60R16 / N BL R / PE ST TL AL3 TR9 - LAMP , GROUP T82 - HEADLAMPS , AUTO ON-OFF CONT T93 - LAMP , TAIL & STOP , SPECIAL T96 - LAMP , FOG UB3 - CLUSTER , INST , OIL , COOL TEMP , VOLTS , TRIP ODOM UK3 - ELECTRONIC SYSTEM , ACCESSORY CONT UQ1 - RADIO PROVISIONS FOR STEREO US6 - ANTENNA , FIXED , PAINTED , RADIO UW4 - SPEAKER SYSTEM , 6 DUAL FRT DASH MTD , F/D DUAL UX1 - RADIO , AM STEREO & FM STEREO , SEEK/SCAN , AUTO REV U25 - LAMP , INTR , RR COMPT , COURTESY U26 - LAMP , INTR , ENG COMPT , COURTESY U29 - LAMP , INTR , I/P , COURTESY VH7 - BUMPER , CUSTOM VY7 - KNOB , TRANS CONT LEVER , LEATHER V56 - LUGGAGE CARRIER , RR COMPARTMENT LID , PAINTED V73 - VEHICLE STATEMENT , USA/CANADA WX2 - SALES , "LEATHER APPOINTMENTS" Y99 - SALES , "HANDLING PKG" Z7M - MODEL CONVERSION - PONTIAC GRAND PRIX SE ODK - SPRING , COMPUTER SELECT REAR (RDK) Spring code FE3 Front Spring RDK GM P/N 17984228 1SB - PACKAGE , OPTION 02 1SZ - PACKAGE , OPTION DISCOUNT 40P - WHEEL COLOR , WHITE 40U - PRIMARY COLOR , EXTERIOR , WHITE 6UY - COMPONENT FRT LH , COMPUTER SEL SUSP (FUY) Spring code FE3 Front Spring FUY GM P/N 14100176 7UY - COMPONENT FRT RH , COMPUTER SEL SUSP (FUY) Spring code FE3 Front Spring FUY GM P/N 14100176 75Q - MOLDING COLOR , BRILLIANT RED MET 82D - TRIM COMBINATION , CLOTH , MED DARK GRAY 82I - INTERIOR TRIM , MED DARK GRAY 829 - SEAT BELT COLOR , MED DARK GRAY LB6 Code W Motor Specs Engine Description (LB6) 2.8L 60 degree V6 Horsepower (HP @ RPM) 130 @ 4800 Torque (ft-lbs @ RPM) 160 @ 3600 Block Cast Iron Heads Aluminum Valves 12 Displacement 2.8L (2800cc, 173ci) Cylinders 6, V formation, opposed 60 degrees Bore 89mm (3.503") Stroke 76mm (2.992") Compression Ratio 8.9:1 Fuel Management PFI (Port Fuel Injection). Electronic, controlled by ECM VIN code W Usage W AND L body cars, 1988-early 1989 Type Gen II Quote
Guest Anonymous Posted February 20, 2004 Report Posted February 20, 2004 So is it heavy duty or not? Is FE3 heavy duty? Quote
no1kicker Posted February 20, 2004 Report Posted February 20, 2004 Yes, FE3 is heavy duty. On that topic, is there a different part # for front struts? I want the KYB's but they don't ask heavy duty or not. Quote
Guest Anonymous Posted February 20, 2004 Report Posted February 20, 2004 Yes, FE3 is heavy duty. On that topic, is there a different part # for front struts? I want the KYB's but they don't ask heavy duty or not. That's what I didn't understand. Heavy duty mounts both no heavy duty struts. Quote
Gearhead43 Posted February 20, 2004 Report Posted February 20, 2004 The KYB's are similar in stiffness to the FE3's.. They might be just a tad softer but they feel like they have better damping control. Anyhow, Struts one level softer with larger rollbars will give you about the same ride as an FE3 without feeling as stiff on smooth roads. Quote
