psykodevul Posted February 15, 2004 Report Posted February 15, 2004 Does anyone know if running ground wire actually do any good. If so how good do they work? Quote
hazmatic Posted February 15, 2004 Report Posted February 15, 2004 Yes. Ground electrical system. duh ppl r stupid even i knew that Quote
gp90se Posted February 15, 2004 Report Posted February 15, 2004 Yes. Ground electrical system. duh ppl r stupid even i knew that I dont believe ya actually knew that There is a reason u have 2 posts on the battery. -Jeff Quote
sl3196 Posted February 15, 2004 Report Posted February 15, 2004 Are you serious? I thought they were for looks! Quote
musthavemuzk Posted February 15, 2004 Report Posted February 15, 2004 well ummmm is this for a car audio setup? mayb explain a little bit here. as you are pretty vague in your question. Monty Quote
Z34door Posted February 16, 2004 Report Posted February 16, 2004 so you drive a bolt into the ground and put a wire one it and attatch it to you car??? sounds like theft detterance Quote
Guest TurboSedan Posted February 16, 2004 Report Posted February 16, 2004 so you drive a bolt into the ground and put a wire one it and attatch it to you car??? sounds like theft detterance actually, you just get a roll of 1500ft of wire and stick it in your trunk. attatch one end to your battery and drive a bolt into the ground with the other end of the wire attatched to it. you should see at least 3/10ths of a second off of your ET. if not, well then you probably need more speed stickers or bright yellow engine wiring loom. or something. joshua Quote
god910 Posted February 16, 2004 Report Posted February 16, 2004 bright yellow engine wiring loom Nope, it's been proven on my ass dyno that ANY amount of yellow wire loom will add the same HP at any given RPM range. For instance, I have it covering the small amount of wire between my alt. and upper plenum, it gives 4000 HP. Any more, and it's just over kill. My ass dyno is +/- 10 HP, so it's pretty accurate. I just had it zero'd last summer. Quote
Guest TurboSedan Posted February 16, 2004 Report Posted February 16, 2004 here is my 5000hp: yep. joshua Quote
