90TGP Posted February 11, 2004 Report Posted February 11, 2004 Ok, my A/C doesn't work, and would have to be converted to R13 to work anyway. I want to install my FMI and was thinking of running the IC pipe through the area the stock intercooler and a/c condensor is. How would I go about removing the a/c condensor and everything attached to it? Is their an a/c idler pully I can put in place of the a/c pully? If their is no pully available, what size belt would I need? How much weight would be removed from the car when removing the a/c unit? Quote
93CutlassSupreme Posted February 11, 2004 Report Posted February 11, 2004 Ok, my A/C doesn't work, and would have to be converted to R13 to work anyway. don't you mean 134A? you're not going to save much weight by removing your a/c Quote
Guest TurboSedan Posted February 11, 2004 Report Posted February 11, 2004 If their is no pully available, what size belt would I need? How much weight would be removed from the car when removing the a/c unit? i would be interested in knowing how much weight you could take off also. i know the compressor is pretty heavy, and all the lines and condensor weight probably adds up. i would just look for a belt from any 2.8/3.1 MPFI car that didn't come with A/C maybe... good luck joshua Quote
