3.1 intake variances
ok my parts car has a 3.1 also but it is a 90 model. i need to know if there is any dofference i was thinkinabout porting the upper and lower intake and gasket matching it and being able to bolt the car together in a day.my car is a 92 vin T 3.1 multiport and the parts car is also a vin T 3.2 i heard about the upper intake gaskets being different but i think i can solve that problem. with just using 90 intake gaskets
at one point the bolt holes and bolts changed size(the ones that hold upper to lower). dunno when but i know 90 and 93 are different
I had a 91 plenum on my 90 motor, the 91 had bolts with rubber boots and the brake booster outlet was different. I used 91 bolts and fab'd up the brake booster line, ran fine till it ignighted.
-Jeff
Guest TurboSedan
-Jeff
i had a '91 plenum on my '90 motor (RIP), and i used the '90 bolts. the bolt holes in the '90 plenum were too small for the '91 bolts because the '91 bolts have a rubber sleeve around them even tho the bolts themselves are smaller - besides the '91 bolts were too small to even thread into the '90 lower intake. gaskets should be the same for every year, but Fel-Pro plenum gaskets are the steel type with rubber o-rings around the ports. the cheaper kind like Niehoff are just paper. if i got new gaskets i would probably just use the cheapo paper variety.
joshua
so if i put the complete intake. upper and lower on i'll have to fab up a brake booster line and thats it??? any variances in the EGR?? i want to use this intake bc my intake has 2 broken valve cover holes in it causing an oil leak.
EGR bolted right on, I used a spare hose I had for a brake line, worked fine. tripple check the plenum gaskets if u have the metal 1s because there not supposed to be reused, and they can leak.
-Jeff
Guest TurboSedan
i dont' remember having a problem with the brake booster vacuum line, but then again it's been awhile :oops:
joshua
my 90 had a differnt size fitting for a brake booster line, the 91 plenum used a smaller hose
-Jeff
well its good to hear........ i'm going to be changing out all the gaskets anyways
vin T 3.2
since when did these cars have a 3.2 liter engine?
i thought it was only the quad four, 2.5 liter 4, some other 4, 2.8 liter v-6, 3.1 liter v-6, 3.4 liter v-6, and 3.8 liter v-6
so you are taking them from your parts car and putting them on a parts car (aka lumina)? :lol:
joey.. funny......... i thought cutlasses were good parts runners..... LOL
it was a typo.. it is a Vin T 3.1 that has been bored out to 3.2 actually
