Thabulldog Posted February 9, 2004 Report Posted February 9, 2004 I got my starter replaced in July and once in a while when I start the car the starter will keep turning over even if the car is running. I can take the key out of the ignition and it'll still do it. It only stops if I turn the key to IGN and back a few times. What could be causing it. Quote
Thabulldog Posted February 9, 2004 Author Report Posted February 9, 2004 Oops, I know this probably belongs in the Powertrain section, I thought thats where I was when I posted. Mods, feel free to move if you so desire. Quote
SmokesGTP Posted February 9, 2004 Report Posted February 9, 2004 I've never heard of that. It could be a problem with the cylinder you stick the key in. I think the ignition lock cylinder is a common thing to go on W-body's from what I've read. Just a shot in the dark. Quote
Z34door Posted February 9, 2004 Report Posted February 9, 2004 if the starter isn't disengaging its either the solenoid or the starter is improperly shimmed. Quote
grandprix104 Posted February 9, 2004 Report Posted February 9, 2004 probably what he said three times - go have it bench tested and/or replaced where you bought it. It sounds as if the solenoid is not releasing causing the starter to keep turning and stay engaged. Quote
GnatGoSplat Posted February 9, 2004 Report Posted February 9, 2004 I had a similar problem where a starter would spin, but not engage the flywheel. I had to replace the starter even though it wasn't very old to begin with. Since yours doesn't shut off when you remove the key, I'm quite certain it's a bad solenoid, but most auto parts stores only sell the starter as an assembly. Quote
Z34door Posted February 10, 2004 Report Posted February 10, 2004 i had that problem too shawn..... it ended up i broke the shaft btw the solenoid and the starter motor and it just sat there and spun. damn bosch parts Quote
Thabulldog Posted February 10, 2004 Author Report Posted February 10, 2004 How hard is the starter to replace on the 3.1 in the Lumina? I sure as hell won't take it back to that same shop, besides the fact the warranty was up last month . I'm planning on doing it next month when it gets warmer out. Quote
Thabulldog Posted February 11, 2004 Author Report Posted February 11, 2004 TTT, Anybody ever done it? Quote
