How to reprogram a Key FOB
How do you do it. And this is for a 1995 Grand Prix Key FOB to be reprogrammed to another 1995 Grand Prix.
1. Open the trunk lid. Remove the carpet trim on the right side. Use a wire and an alligator clip to ground the connection. Your locks should cycle. This indicates your system is in programming mode.
2. Press and hold any button on the transmitter. The door locks and trunk release will cycle in about two seconds. Once you're done, disconnect the grounding wire, and tada.. it's complete.
I think also if you have 2 FOBS leave that wire grounded until both FOBS are programmed.
