grandprix104 Posted February 6, 2004 Report Share Posted February 6, 2004 Is it possible to remove the pan without dropping the subframe and all the BS chilton says you need to due. I believe/hope this is where my leak is coming from but im not sure. Quote Link to comment Share on other sites More sharing options...
manitcor Posted February 6, 2004 Report Share Posted February 6, 2004 nope, there is a specail GM tool that supposedly makes it easier. From what I have read about the proccess im of the opnion it would be quicker to do this by just removing the engine. Quote Link to comment Share on other sites More sharing options...
grandprix104 Posted February 6, 2004 Author Report Share Posted February 6, 2004 whoever designed that should be kicked in the balls repeatedly That is the stupedest design ever! Quote Link to comment Share on other sites More sharing options...
93GTP Posted February 6, 2004 Report Share Posted February 6, 2004 Yep, w-bodies are definetely full of shitty designs. All GM cars are for that matter..... Quote Link to comment Share on other sites More sharing options...
Goph Posted February 6, 2004 Report Share Posted February 6, 2004 Yep, w-bodies are definetely full of shitty designs. All GM cars are for that matter..... yep. hell because you couldn't take the oil pan off easy with out taking the engine out it took a extra week to see what all i did to my engine and if it was worth rebuilding when i blew it. Quote Link to comment Share on other sites More sharing options...
