Timing chain
My question is for the crankshaft gear can you use a three jaw puller or is their a special puller you need to use to remove it. And, to install it is their any special tools that you would need to use to get it on.
Thanks for any help
Are you talking about the crank pulley or the crank gear?
Just tap it off and tap it on. Use a screwdriver and just tap the gear off
