robertg Posted February 4, 2004 Report Posted February 4, 2004 the car is a 90 lumina base model with euro rims. i went to the tire shop today, and found out that the rear tires are wearing unevenly.... the wear is most evident on the tread of the tire, along the edge facing the inner wheel wells. so it looks like i'm getting new tires in the spring. i'm wondering... this car has the trailing arms..... could they be bent? thanks in advance. Quote
Intimidatorz34 Posted February 4, 2004 Report Posted February 4, 2004 check the trailing arms and lateral links along the leaf springs to see if they are bent. The lateral links get bent pretty easily if someone doesnt know what they are doing if they tow the car. Quote
robertg Posted February 4, 2004 Author Report Posted February 4, 2004 i'll check into it as soon as i can. thanks! Quote
lilloon Posted February 5, 2004 Report Posted February 5, 2004 have yer alignment checked. you prolly got too much negitive camber. Quote
EurosportZ34 Posted February 5, 2004 Report Posted February 5, 2004 Have you or the previous owners rotated the tires before? That helps so they wear evenly. Quote
PaPaPooh Posted February 5, 2004 Report Posted February 5, 2004 rear tires cross the driver and fronts come straight back Quote
