Glasspack?????gets thicker!!! I posted in wrong spot before
I've been wanting to ask which way my Flow Tech glasspack should go in...(which way the scallops inside should point). My Bike has them with the cuts facing rearward, ie: flow would run over the smooth edges rather than impinge on the cutouts.
But now guys on the Monte forum are talking about installing glasspacks backwards...on purpose. Ideas anyone??????
Oh yeah, my Flow tech "Purple Hornies" ain't purple anymore. It came out of the box with flaked off paint all around it. Course grit cardbaord??
Anyway it's hi temp silver now.
Brian P.
How would you install it??
Thanks.
My brakes are 1/2 done but at least the new rotor is on. Smooth braking now. That rotor was major bad. Glazed rust!!!!!
that is the correct way. the loovers should be facing to the rear of the car. the air is supposed to travel over the "Scallups" the smooth way.
RedZ
what would be the point of facing it the other way?
No point in putting them in backwards.. other then increasing back pressure..
