Bake82 Posted January 31, 2004 Report Posted January 31, 2004 Hey guys, I'm looking at this Clarion amp http://www.etronics.com/product.asp?stk_code=claapx2012&store=&catid=303 and this rockford amp http://www.etronics.com/product.asp?stk_code=roc201s&store=&catid=303 It will be bridged to a 200 watt sub. Any opinions on these amps? I'd like to pick one of them up by wednesday at the latest. Note I will be buying locally and can get them both at the same price, so price isn't an issue. Thanks for your opinions! Quote
rudefyet Posted January 31, 2004 Report Posted January 31, 2004 depends on the use....is 200 watts the most power you can use. Rockfords are underrated and have a lot of brute power while Clarions have better Sound Quality and are closer to the actual power rating best bet Subs=Fosgate Highs=Clarion the Clarion only puts out 100 watts bridged while the fosgate will actually put out around 250 or 275 watts...so you may want to take that into consideration the clarion is rated 200 watts max!! you need to buy stereo equipment by rms ratings not max!!! so the clarion is less powerful then the fosgate but the fosgate has a 200 watts rms rating...but if you need exactly 200 watts find a clarion rated at 200watts "RMS" reason being...max output is what it can handle at a musical peak...which is hard to explain...RMS is the contiuous wattage put out by the amp...make sure to match it up with your speakers to...if your speakers say 300watts max...DO NOT buy a 300watt rms amp...but if your speakers say 300watts RMS or nominal...then a 300 watt rms amp would be perfect Quote
phantomFE3 Posted January 31, 2004 Report Posted January 31, 2004 depends on the use....is 200 watts the most power you can use. Rockfords are underrated and have a lot of brute power while Clarions have better Sound Quality and are closer to the actual power rating best bet Subs=Fosgate Highs=Clarion the Clarion only puts out 100 watts bridged while the fosgate will actually put out around 250 or 275 watts...so you may want to take that into consideration the clarion is rated 200 watts max!! you need to buy stereo equipment by rms ratings not max!!! so the clarion is less powerful then the fosgate but the fosgate has a 200 watts rms rating...but if you need exactly 200 watts find a clarion rated at 200watts "RMS" reason being...max output is what it can handle at a musical peak...which is hard to explain...RMS is the contiuous wattage put out by the amp...make sure to match it up with your speakers to...if your speakers say 300watts max...DO NOT buy a 300watt rms amp...but if your speakers say 300watts RMS or nominal...then a 300 watt rms amp would be perfect here; get the RF. (rockford fosgate) Quote
rudefyet Posted January 31, 2004 Report Posted January 31, 2004 oops changed my mind...um the clarion is rate 230 typical watts bridged....guess they're underated too...lol the Fosgate will give ya more boom though Quote
Dannymik Posted January 31, 2004 Report Posted January 31, 2004 RF all the way! My personal favorite when I competed in the car audio stuff was SOUNDSTREAM. I check the rubicon series out on Ebay whenever I remember. I had the Soundstream Rubicon 702...killer amp! Quote
92Cutlass4Dr Posted February 1, 2004 Report Posted February 1, 2004 i would say it comes down to looks more than anything. you are looking at almost identical specs on the entry level amps from each company, so neither is really cutting edge. you could try going to a high-end car audio store and see if they are getting rid of some demos, it's very likely because the consumer electronics show just happened and you will find a lot of places making space for new models. the demo amps rarely have a lot of time on them, and they will come with the full manufacturer warranty. you might find an awesome deal Quote
Goph Posted February 1, 2004 Report Posted February 1, 2004 RF all the way, i have a rf120.2 and love it. Quote
jeremy Posted February 2, 2004 Report Posted February 2, 2004 Although I like the previous series of RF amps better then the new ones, I would still tell you to get the RF....you can't go wrong with Fosgate Quote
musthavemuzk Posted February 3, 2004 Report Posted February 3, 2004 may as well chime in here not a RF fan at all but would still get something other than clarion for an amp. head unit i would do clarion, but not amp. when i got into car audio clarion amps was way high in price for what you got. mayb have changed in the last few years though. Monty Quote
jeremy Posted February 3, 2004 Report Posted February 3, 2004 if you are going outside of the two choices, I would personally go with PPI Quote
Bake82 Posted February 3, 2004 Author Report Posted February 3, 2004 Hey guys, thanks for opinions, I went ahead and got the RF one. The stat sheet says it puts out 275 rms @ 4 ohms, so it's got plenty of power for the sub, Thanks again for you thoughts on helpin me out! Quote
musthavemuzk Posted February 4, 2004 Report Posted February 4, 2004 PPI is good got a couple three myself Monty Quote
Z34door Posted February 4, 2004 Report Posted February 4, 2004 ok to lay it out clear .. the difference between RMS and peak is that RMS is continuous load and peak is what it can handle if stuck by lightning........ basically its what you can give it for a split second not continuously Quote
Bake82 Posted February 4, 2004 Author Report Posted February 4, 2004 ok to lay it out clear .. the difference between RMS and peak is that RMS is continuous load and peak is what it can handle if stuck by lightning........ basically its what you can give it for a split second not continuously Yes, I know that. I was looking at RMS. The clarion said it put out around 230 RMS, the other guy thought it was 200 peak. I knew it was ~200 RMS. Thanks tho for the explanation. Quote
sonyman87 Posted February 4, 2004 Report Posted February 4, 2004 Rockford has better Amps IMO Clarion has better Headunits when you compair the two Also clarion speakers kickass stay away from rockford subs!!! Quote
