stlunatics2oo3 Posted January 29, 2004 Report Posted January 29, 2004 okay i have a problem with my windshield wipers they like to stay on even when the switch is in the off postion. i replaced the switch with a band new one today still no luck so my question is: is there a relay or fuse that is blown ?? or is the motor messed up? i checked the fuse that is under the glove box its not blown thanks Jeremy ps. if the motor is blown how do i fix it ? also is there a way to put the regular wipers on like the side to side ones ? Quote
mfewtrail Posted January 29, 2004 Report Posted January 29, 2004 Jeremy, are the wipers on ALL the time now? If so, you've got a short to ground on the ground side of the load component before the grounding switch..therefore, you can't turn the wipers off. EDIT: had to rethink that for a sec Quote
stlunatics2oo3 Posted January 29, 2004 Author Report Posted January 29, 2004 no the wipers are not on all the time if i mess with them for 2 minutes or so it will shut off but its annoying thanks Jeremy Quote
J Posted January 29, 2004 Report Posted January 29, 2004 no the wipers are not on all the time if i mess with them for 2 minutes or so it will shut off but its annoying thanks Jeremy same with my winter beater Quote
jeremy Posted January 29, 2004 Report Posted January 29, 2004 I hate the wipers on w-bodies..... Quote
