90KUTTY Posted January 26, 2004 Report Posted January 26, 2004 i keep on gettin code 45, what could it be maybe the o2 sensor gone bad? thanx Quote
Redfox340 Posted January 26, 2004 Report Posted January 26, 2004 Could be, but also double check your MAP sensor. A vacuum leak will cause the ECM to run a rich condition. - Erik Quote
90lum31v6euro Posted January 26, 2004 Report Posted January 26, 2004 my service engine soon light pops on and stays on when i push the car past 5200 on the tach. it just comes on and stays on solid, no blinking the car runs fine, no erratic idle or anything and when i shut the car off for about 5-10 seconds, it goes away is it anything i need to worry about? Quote
Redfox340 Posted January 26, 2004 Report Posted January 26, 2004 is it anything i need to worry about? Yeah, even though the SES Light is not flashing, it's still an issue. You don't want it to flash, flashing indicates a severe problem detected by the ECM. You'll want to ground / scan the system ASAP: W-Body Performance - OBDI Diagnosis. Even the light goes away, the ECM still keeps a record of the faulty circuit. - Erik Quote
