kcac Posted January 25, 2004 Report Posted January 25, 2004 When you disconnect the battery on a 1995 Cutlass (e 3.4 L engine), how do you remove the cable going to the positive terminal? It looks like it has a "cap" of some sort with two small red wires coming off of it. I started prying on it, but it's 15 degrees farenheit here today, and I was worried the plastic piece would be brittle from the cold and break. That and I had forgotten to bring an extension to get the bottom battery clamp bolt loose, so it wasn't worth pushing it since I couldn't get the battery out anyway. Quote
mihela816 Posted January 25, 2004 Report Posted January 25, 2004 The cap is just there to keep the positive terminal from grounding out. Just pull it off and there should be a terminal just like the negative, 8mm wrench/socket/whatever Quote
kcac Posted January 25, 2004 Author Report Posted January 25, 2004 Thanks mihela816 By the way, what if you need a jump or have to give on to someone else. Is there an alternaive place to connect the positive jumper cable since the battery is so buried in that car? Quote
GP1138 Posted January 26, 2004 Report Posted January 26, 2004 There should be another positive terminal, up by the driver's side strut cap, right next to the fuel pump fuse and relay. Just pull the cap off of it, and clip your jumper cable to it, and then I clip the negative to the right bay brace. YMMV Quote
