Pogo420 Posted January 24, 2004 Report Posted January 24, 2004 Ok i start my car in the morning, put in reverse, pull out of drive way onto street, i put it in drive, nothing, nothing at all, so i go thru all the gears and NOTHING its like its in Nuetral in ever gear i put it in, i put in park then drive even reverse again, nothing at all whutsoever, and then i shut it off..jus for second, turn it back on, put it in drive, and i pull away...this has happen twice now, so far only when its cold really cold, like the other night 0 below chicago cold HELP anyone! Quote
PaPaPooh Posted January 24, 2004 Report Posted January 24, 2004 fluid level ok? let the car warm up more Quote
Robby1870 Posted January 24, 2004 Report Posted January 24, 2004 let the car warm up more Thats the answer to your problem Quote
Pogo420 Posted January 27, 2004 Author Report Posted January 27, 2004 fluids are fine, but i've been meaning to change it...is there an easy ghetto way to flush the tranz? i've heard starting the car to get the converter to empty but thatz it..and i don't know if thats even a good idea? Quote
Robby1870 Posted January 27, 2004 Report Posted January 27, 2004 If you wanna change the fluid, just drop the pan. You'll get about 1/2 of the fluid changed. If you are really interested in getting a lot of it changed, drop the pan again about 500 miles after the 1st time. But really, its not worth it Quote
Dan94Z34 Posted January 28, 2004 Report Posted January 28, 2004 what car are we talking about there. I know the tranny's that were the 3100's have a transmission delay problem. It was due to the valves in the valve body letting pressure by until it warmed up, and expanded causing the leek to be sealed. The only fix is a new valve body. Not cheep. Quote
Pogo420 Posted April 17, 2008 Author Report Posted April 17, 2008 AWAKE FROM THE DEAD! ok before you freak on the 4 year old post, i just started driving this car again as my beater and i'm checking out the replies i never read.... ok its not the 3100 but its the 2.8 which i know is very similar but is it close enough to have this same valve body problem? Quote
