Intlcutlass Posted November 13, 2002 Report Posted November 13, 2002 I finally figured out how to post pics......as you can see, my cyl walls are bad...But, the crankshaft looks great, and for whatever reason the crossover looks great too. I removed the shield and the flex joints look great...no cracks. It's cool when not everything goes wrong! Quote
TGPilot Posted November 14, 2002 Report Posted November 14, 2002 Give her a quick honing and she'll be mint!! 8) How does your Dual Friction Centerforce hold up for you? I have some slippage that doesn't seem to be to good lately. When you bolted your slave cylinder up to the tranny...was the rod at the tranny fully extended? If so...did it require a bunch of pressure to get the rod into the slave cylinder so that you could start the nuts to mount it? Quote
Jeorge Posted November 14, 2002 Report Posted November 14, 2002 that pipe almost looks like a Rebuilt on not an origanal...hmmm..... Quote
Intlcutlass Posted November 14, 2002 Author Report Posted November 14, 2002 I have not installed the centerforce yet. It's sitting right next to the 282 on the floor. I have to finish rebuilding the engine first. Money is the biggest roadblock I have right now what with the holidays creeping up-n-all. I will let you know though cause the slave mine came with was cracked, so i went up to the yard & snagged another one. I had to cut that shield off the crossover so I'm pretty sure it's the original, I was also amazed at how flexable ( and potentially fragile) those flex joints were. The only stuff i need to but now are the Pistons (mahle) And the radiator (recored) and Fan Rings (total seal) Bearings I CANT WAIT !!!! And I know my brother-n-law wants to get it done quick too, cause my engine is on his stand, and we are picking up his 88 fiero formula this weekend. Quote
