Mint Euro92 Posted January 19, 2004 Report Posted January 19, 2004 Does anyone know if there is a factory rev limiter on a 92 3.1 ? I was working on the car cleaning the throttle body . And after starting it up to clear the cleaner out it seems it wont rev past 4k in neutral just seems to bounce off a limiter. It runs & drives fine otherwise Quote
Robby1870 Posted January 19, 2004 Report Posted January 19, 2004 Its designed to do that so you dont blow the motor. In gear rev limiter is round 6200 and neutral/park is 4000 Quote
Mint Euro92 Posted January 19, 2004 Author Report Posted January 19, 2004 Thanks Robby, Thats what I love about this forum fast straight answers no bs :worship: Quote
Thabulldog Posted January 19, 2004 Report Posted January 19, 2004 Theres an in gear rev limiter at 6200? I know there is the 4200 limiter in Park. Ive hit 7000 many times in gear Quote
jeremy Posted January 19, 2004 Report Posted January 19, 2004 Theres an in gear rev limiter at 6200? I know there is the 4200 limiter in Park. Ive hit 7000 many times in gear that is because luminas rock..... Quote
supreme_style21 Posted January 19, 2004 Report Posted January 19, 2004 Theres an in gear rev limiter at 6200? I know there is the 4200 limiter in Park. Ive hit 7000 many times in gear that is because luminas rock..... My lumina never had an RPM gauge.. so I couldn't tell ya.. I wouldn't doubt it if I've hit that high before though :oops: Quote
Thabulldog Posted January 19, 2004 Report Posted January 19, 2004 Wouldn't it be the same for all 3.1s? Quote
Chinski Posted January 19, 2004 Report Posted January 19, 2004 It might be because your lumina is a '90. My 90 lumina does not have a rev limiter or a governor and my buddies 92 lumina does. My guess is that it was added when GM went to the 4t60E, instead of the 4t60 like the 90 luminas had. Quote
Robby1870 Posted January 19, 2004 Report Posted January 19, 2004 92 3.1Ls had 4T60. 60E was not given to a 3.1L until 93 Quote
Thabulldog Posted January 19, 2004 Report Posted January 19, 2004 It might be because your lumina is a '90. My 90 lumina does not have a rev limiter or a governor and my buddies 92 lumina does. My guess is that it was added when GM went to the 4t60E, instead of the 4t60 like the 90 luminas had. Well I have a limiter at 4200 in park, and nothing else I've found in gear. Like I said before I've hit 7000 a few times and backed off when I saw the engine speed. I have a governor at 119mph. Quote
joey b Posted January 20, 2004 Report Posted January 20, 2004 your pushrod hit 7K? :shock: I thought those redlined at 6 and I remember Ben saying that they had an ingear limiter of 6212 Quote
Thabulldog Posted January 20, 2004 Report Posted January 20, 2004 your pushrod hit 7K? :shock: I thought those redlined at 6 and I remember Ben saying that they had an ingear limiter of 6212 I was well into the redline. I happened to be racing my friend and I looked down and saw where the needle was and let off the gas immediately. Quote
supreme_style21 Posted January 20, 2004 Report Posted January 20, 2004 Like I said, mine didn't have the RPM gauge, but I believe the highest it has ever ran is when I was going about 75mph in 2nd. gear. :? I had the radio turned up so loud, I didn't hear anything abnormal. I don't know what the RPMs would have been, but dangerously high, I imagine. Quote
Vegeta Posted January 20, 2004 Report Posted January 20, 2004 Ive had mine shift at 80 in 2nd, and its not 7000. It was just above 6000. Quote
skalor Posted January 20, 2004 Report Posted January 20, 2004 I was well into the redline. I happened to be racing my friend and I looked down and saw where the needle was and let off the gas immediately. Your tack it off and that's why it's seems to be revving so high. I just put a turbo 3.1 in a euro lumina and the tack reads the park limiter as 4,000 rpms when in reality I know it to be 3,000. Quote
dbtk2 Posted January 21, 2004 Report Posted January 21, 2004 Your tach is definately off. If I believed my tach, that means my TSTE idles at 1500rpms, cruses down the freeway in overdrive at 3500rpms, has an in park limiter of 4200rpms, and shifts at about where 7500rpms would be on the tach if it went that far. You can't really trust the factory tachs in these cars. My guess is that your car is shifting around 5500-5800 rpms. Shawn Quote
Z34door Posted January 22, 2004 Report Posted January 22, 2004 no 4t60 bullshit here...... th125c.... shifts out of 2nd at 95 mph at 6700rpm i've hit 50 mph in 1st gear and its roughly 7200rpm. Quote
Nick1234 Posted January 22, 2004 Report Posted January 22, 2004 my car will not go above 5500, unless you put the car in nuetral, and let the cruise control take it up past redline. My car though is gay, while having it in gear at about 4400 rpms, its like the fuel shuts off, and i can't figure out why, and it doesn't do it all the time. Quote
