icm?
you can check for spark to all of the cylinders. If they all have spark test the resistance in the spark plug wires. Let us know what you find.
I've also notice that when the ICM goes bad it often starts intermittently. It will run like ass then run fine then like ass then fine, but it still may be the ICM if that isn't the case for you. If you have 2 cylinders misfire are they on the same coil? If you have 3 it is the ICM (happened in 2 cases to me).
well guys.. it was a burnt out fuzable link to the ecm - fuel pump terminal... she runs like a champ now... so
thanks for the help..
later
joe
what kind of probs were you having? Where did you find the burnt fusible link?
my car having probs and i already ordered a new ECM but tell us wat fusible link it blew?
