tgpguy21 Posted January 17, 2004 Report Posted January 17, 2004 Ok so I bought this TGP from Idaho and on the way back I noticed some things that were wrong with it. Obviously the cross over is bad as well as the O2 sensor. There seemed to be oil running through the intercooler and the intake, Bad turbo seals?? The brake lights dont work at all. The dim brake lights come on when you turn the headlights on but they dont get bright when you step on the brakes. Hud shows all the symbols being on all the time? Dash lights dont work except blinker lights, bright lights symbol, and the Anti lock brake light is always on. If anyone has any ideas on how to fix the brake light problem let me kow im thinkin its a bad ground or fuse?? Any help would be appreciated. Quote
Guest TurboSedan Posted January 17, 2004 Report Posted January 17, 2004 i would guess a bad brake switch. pita to replace - it's way up under the dash near the top of the brake pedal. joshua Quote
