coolant sensor light!!!!
89BuickRegalGS
My coolant light is coming on (on the dash) when I start the car, stayiong on longer than ussual, then after i reach (i assume so anyways) a running tempurature, it shuts off... any ideas?
Mine did the exact same thing! Your coolant it just a little low. Wait till it's cool, then top it off. The problem should go away.
I have a same problem in my 88 CS and it goes away when it reaches normal temperature, i added more cooland and even flushed a radiator and puta new fluid and its still doing the same. I think it migh be a coolant sensor that is going bad. :shock:
that is exactly what my monte is doing. it comes on then goes off then comes on and goes off a few minutes later. its the coolent temp sensor i was told. my coolent is full so i am just going to say *F* it for now and fix it when i have things tore apart for the turbo.
RedZ
