IAC Cleaning
grandprix104
anybody done this that carezs to share the process. Also whats the procedure for removing the TB to clean?
clean the IAC spring with a carb cleaner. To take the TB off, take the intake hose off (should be a screw clamp) then take off the two TB bolts and then the throttle linkage. Replace TB gasket. Take off IAC motor, check O-ring on IAC. Put back together, easy
