jheiv Posted January 15, 2004 Report Share Posted January 15, 2004 My car didnt start today, so I pulled the front three plugs. All of them were wet with fuel and covered with black soot. What would cause black plugs? More importantly though... what would cause WET plugs? Thanks Quote Link to comment Share on other sites More sharing options...
GnatGoSplat Posted January 15, 2004 Report Share Posted January 15, 2004 Wet plugs = no spark. Bad ignition module or crankshaft position sensor. Quote Link to comment Share on other sites More sharing options...
jheiv Posted January 15, 2004 Author Report Share Posted January 15, 2004 Shawn - I get spark -- I drive the car -- its just sometimes when I will come back out to it I have wet plugs and no start. I carry around a ratchet and 3 plugs that I replace when this happens. I just clean the wet pair after I get home and put them back until next time I come out and they're wet. BTW-- i just replaced CPS and DIS mod. Quote Link to comment Share on other sites More sharing options...
mfewtrail Posted January 16, 2004 Report Share Posted January 16, 2004 Does it only have trouble starting when hot(after being driven)?..sounds like you may have a fuel pressure regulator that is bad..if fuel is in the vacuum line, it needs replacing..I would check right at the FPR, just pull the brittle/plastic vac line off(probably going to have to pull the plenum..even if you could get to it without removing the plenum, you would probably break those plastic lines. Quote Link to comment Share on other sites More sharing options...
PaPaPooh Posted January 16, 2004 Report Share Posted January 16, 2004 sounds like stuck open injecters to me i could be way off here? Quote Link to comment Share on other sites More sharing options...
GnatGoSplat Posted January 16, 2004 Report Share Posted January 16, 2004 sounds like stuck open injecters to me i could be way off here? That is possible too. The way to test for this is to put a fuel pressure gauge on the fuel rail, start the car and check fuel pressure (should be 35-45psi I think). Then shut off the car and watch the rate that the pressure bleeds down. A little leakage is normal... I'd have to look up what the acceptable rate is. Quote Link to comment Share on other sites More sharing options...
topless94style Posted January 16, 2004 Report Share Posted January 16, 2004 Something definitaly with the fuel. Test the FPR and injectors see what you come up with. Quote Link to comment Share on other sites More sharing options...
