topless94style Posted January 9, 2004 Report Share Posted January 9, 2004 Yea, that black box that is above the battery, where the positive cable goes to. I lost the original nut for that during the summer, so i put a new one on. Well, something has come loose and now even with this nut as tight as it can go, it wont hold the wire on there tight enough for a charge. You can barely touch from underneath the wire bringing the wire up just barely and have a good connection. As soon as you let go, no power. Anyone know how i can fix this? I got a cresent wrench holding the wire up right now that i stole from my friend since i was at his house. The bottom of the wrench is jamed between some wires and the wheel well, and the top is holding the wire up. Sturdy, but not a permanent fix. Quote Link to comment Share on other sites More sharing options...
BurneroftheRice Posted January 10, 2004 Report Share Posted January 10, 2004 electrical tape...nuff said Quote Link to comment Share on other sites More sharing options...
Justin Posted January 10, 2004 Report Share Posted January 10, 2004 Stack some washers in there. Any way you do it you're going to have a bad connection, lots of corrosion, but at least you'll be able to drive it. Best way would be to go to a junkyard and get the right nut. They should be the same for any W, probably lots of other GMs too. Quote Link to comment Share on other sites More sharing options...
topless94style Posted January 10, 2004 Author Report Share Posted January 10, 2004 I got the right nut, i bought it from the dealer. Spendy bastard, $7. No other nut would fit, I dont know if any of you have tried, but i tried probably 20 nuts and not one worked, so i went to the dealer. As far as electrical tape, that didnt work as well. For now, i got a zip tie holding the wire up, thats the best i can do for now, i just got my exhaust done. Quote Link to comment Share on other sites More sharing options...
Bolt_Crank Posted January 11, 2004 Report Share Posted January 11, 2004 maybe replace the entire post? it seems like something in it is funked... maybe the whole box if you can get one dirt cheap from the jy Quote Link to comment Share on other sites More sharing options...
