cutlsp Posted January 8, 2004 Report Posted January 8, 2004 okay my cutlass has a weird drip of fluid that turned white after it rained i don't know what the fluid could be but i need to find out soon okay give me all your ideas about it and i'm tired from so lay off about no damn puctuation oh and i can't spell when i'm tired either Quote
joey b Posted January 8, 2004 Report Posted January 8, 2004 hey guys, my car doesn't run. Any ideas? Quote
Slade901 Posted January 8, 2004 Report Posted January 8, 2004 Battery acid leaking? What area in your car does this leak coming down? Quote
jpv123 Posted January 8, 2004 Report Posted January 8, 2004 It sounds like the custubilator gasket or the finigan pin. Quote
jpv123 Posted January 8, 2004 Report Posted January 8, 2004 we nee more info about the leak. I had/still have an oil leak an the oil turned like a coffee white color bafter it rained. Quote
Intimidatorz34 Posted January 8, 2004 Report Posted January 8, 2004 i had tranny fluid and radiator fluid mix on the ground while it was rainign and it turned white the next day in the driveway Quote
Ribbie Posted January 8, 2004 Report Posted January 8, 2004 okay my cutlass has a weird drip of fluid that turned white after it rained i don't know what the fluid could be but i need to find out soon okay give me all your ideas about it and i'm tired from so lay off about no damn puctuation oh and i can't spell when i'm tired either Note the location...... Oil and water mix and result in a milky colour....... D Quote
zachismisit Posted January 9, 2004 Report Posted January 9, 2004 It sounds like the custubilator gasket or the finigan pin. maybe you should check your muffler bearings too Quote
rudefyet Posted January 9, 2004 Report Posted January 9, 2004 It sounds like the custubilator gasket or the finigan pin. maybe you should check your muffler bearings too You forgot to mention checking the headlight fluid Quote
Dan94Z34 Posted January 9, 2004 Report Posted January 9, 2004 no no no no its blinker fluid . If you put high performance blinker fluid in you'll gain 20hp Quote
GrandPrix34 Posted January 9, 2004 Report Posted January 9, 2004 cmon peeps, help the man!! Don't know, ebst thing you can do is keep keeping an eye on the fluid and locatoin. Quote
rudefyet Posted January 9, 2004 Report Posted January 9, 2004 sorry...my best guess is oil...i've seen some weird looking oil coming out of a nissan with a blown head gasket...and besides that seems to be what our cars leak best...don't rule anything else out though...check and see what it looks like when its dry Quote
hazmatic Posted January 9, 2004 Report Posted January 9, 2004 brake fkuid turns white i learned the hard way Quote
cutlsp Posted January 10, 2004 Author Report Posted January 10, 2004 ok i have not made any special mods like apc parts for my cutlass fools. i'm going to change the oil tomorrow and dump some barr's sealent in the power steering pump and in with the oil heres hopeing the leak gets stoped :| its coming down in front of the passenger side of my 1988 cutlass Quote
joey b Posted January 10, 2004 Report Posted January 10, 2004 if it's on the pass side I'd say scratch the barr's leak in your engine unless you want to replace that next. Quote
cutlsp Posted January 11, 2004 Author Report Posted January 11, 2004 i don't fuckin care about the engine anymore i want a tgp motor or at least a 3.1 fuckin don't ever take you car to the speedee lube on monfort in dallas texas its next to a firestone tire store they fucked my motor up all around the damn oil pan cause they over filled my motor damn it they won't fuckin pay for it either now i'm gonna have to take fuckin legal action againest them basterds their gonna pay for the repairs at least that its a fuckin pain in the ass i don't have time for this shit i told the fuckin basterds my manual says its suppose to only get 4 quarts this shit freakin sucks worst part is i'm broke right now does anybody have a running parts car that does not leak any oil? Quote
Pogo420 Posted January 11, 2004 Report Posted January 11, 2004 my car had the same white leak in the last couple weeks. i have all my fluids leaking quite literally! buts its cleared up since fixing waterpump and powersteering pump, both were leaking a bit, but still gotta fix tranz pan leak and oil leak, and tranz line leak, and then all the mystery onez!! Quote
cutlsp Posted January 11, 2004 Author Report Posted January 11, 2004 good news not only were those fuckers over filling it they were using the wrong size oil filter too damn basterds i can't decide what to do but the good news is the car is not leaking anymore oil i'm gonna send their freakin post card back and write on it i will never take my cars back to you ever again so just remove me from your mailing list. the important thing is its fixed all except for a minor powersteering leak :? Quote
Guest Gp crazy Posted January 15, 2004 Report Posted January 15, 2004 look at the coolant lines they run on the passenger side. it may be one of the steel/tin lines that GM put there :dammit: it may have rusted out from the in side out or out side in :bawl: depends where you live if you live in up state ny most likely out side in . just a thought 8) good luck Quote
joey b Posted January 15, 2004 Report Posted January 15, 2004 if the filter is larger then don't worry about it. Many oil change places will only stock the larger since they are interchangable. A larger filter won't hurt anything. Quote
excelsior Posted January 16, 2004 Report Posted January 16, 2004 i had this problem on my old car....what happened was the oil and other fluids mixed somehow (forget which ones altho i want to say tranny fluid even tho this doesnt make sense) Quote
mfewtrail Posted January 17, 2004 Report Posted January 17, 2004 I've seen some brands of ps fluid that are milky white in color..check the ps lines and the reservoir/pump and see if you see any leaks..if the lines aren't tight enough running into/out of the pump, it will leak fluid, the fluid will run down the ps lines and drip down about inline w/ the rear of the engine on the passenger side(from what I've seen..my lines were loose so a little fluid leaked out) Quote
Lee Posted January 24, 2004 Report Posted January 24, 2004 The wife's Intrepid left a 4 foot long, 8 inch wide drip down the driveway awhile back. It was an amber fluid that I just couldn't figure out. It matched nothing. Finally I decided it must be a ruptured fluid filled motor mount. Still haven't checked it out. I really aught to. Runs and rides as fine as ever. Quote
Pogo420 Posted January 24, 2004 Report Posted January 24, 2004 power steering fluid or tranz fluid mixed with anitfreeze usually from the waterpump and power steering pump or powersteering lines when on the passenger side Quote
