dis in a 94 cutty
HELP!
I'm having trouble with my DIS
I did find this harness though, is that anything? or do i have to splice everything? ( i started to but couldn't get power other than a few blips on the screen)
  • Replies 87
  • Created
  • Last Reply
Top Posters In This Topic
  • rockfangd
    25
  • Psych0matt
    21
  • GnatGoSplat
    14
  • toastemcutlass
    4
That harness you found is for the HUD controller.
Yes, you do have to splice everything to put DIS in a 94 Cutlass.
Would it just be plug and play or would it need rewiring? I don't mind the gaping hole in the dash part, just the rewiring part.
It's been awhile since I had a Bonneville HUD in front of me, but it would require rewiring and dash modification. The Bonneville HUD is HUGE and differently shaped. I seem to recall it had different connectors too.
I would get a Cutlass HUD, it's plug & play.
While we're on that, I want one too now that i don't have as much modifying to do it :-) (i guess ill check ebay and the for sale section)
Ok, so I have mine all powered up and everything, but still cant figure out where the three data wires go to. It says the aldl connector. What is that? and do all three go to that? thanks a bunch
Are you talking HUD or DIS?
I don't know what's done in '94+ cars, but as said in this topic..
DIS:
The BLACK connector is C2.
Wire A is ORANGE. Connect this to the ORANGE wire
coming out of the ALDL connector under your dash. This
is your SERIAL DATA INPUT where the DIC will get the
info for your gauges button.
Wire B = DARK GREEN. Connect this to the DARK GREEN
wire in the dash. This is your Vehicle Speed Input. In
my car it is wire number D15.
Wire C = PINK. Connect this one to the PURPLE wire in
the dash. This is your vehicle Fuel sender wire. In my
car it is wire number D13.
Wire D = BLACK/GREEN. This is another GROUND. It is
not used in the 91 model.
I orange wire (wire a) is the only one going to the ALDL connector. it should be a plug right in the driver foot well, next to where the console ends.
Wire B and C get wired to wires in your cluster's harness.
and then of course black/gr is a ground
  • 4 weeks later...
I got the DIS all installed and everything, and I knew that the fuel econ stuff wouldn't work, but is the trip info and stuff supposed to be able to? if anyone knows please let me know how
  • 5 weeks later...
any help with my last post? just thought id bump it :-)
Id like to get at least the trip info working, as well as the fuel econ (with some wiring probably)
  • 2 years later...
This is a copy of one of the emails i got from somebody from this message board long time ago and it helped me.
The BLUE connector is C1.
Wire A = a RED wire. Connect it to an ORANGE wire that
is HOT ALL OF THE TIME. (I connected mine to the
ORANGE wire that gives power to the cigarette lighter,
but it is recommended that you connect it to the ELEC.
Fuse #2 constant +12V (top row, middle fuse).)
Wire B = PINK/BLACK. Connect it to a wire that is HOT
IN RUN. (I connected mine to one of the PINK/BLACK
wire in my dash, but it is recommended that you
connect it to CLUST. Fuse #9 switched +12V (3rd row,
far right).)
Wire C = BROWN. Connect it to the light on input. In
my car I have a YELLOW wire in slot C10 but I think
that that is exclusive to the digi-dash. I want to soy
that there should be a YELLOW wire coming out of the
headlight switch that should work. I know that on my
dash, when the lights are on, and the display is at
MAX, then it has no power in the wire, but when I
adjust the lever down, the wire becomes hot, and dims
steadily. I use a tester that is just a screwdriver
looking thing that has a point at one end, and an
alligator clip that you hook up to ground.
Wire D = GREY. Connect this to one of the grey wire
for illumination. I hooked mine up to the GREY wire
that lights up the bulb for the cigarette lighter
light.
Wire E = BLACK/WHITE. This is a ground.
Wire F = BLACK/GREY. This wire is not used.
Wire G = YELLOW. Connect this wire to the LITE BLUE
wire in the dash (You may not have this wire). This is
your English/metric wire. In my car, I push a button
on the dash to change it from English (MPH) to metric
(KPH). When this wire is hooked up, it automatically
changes the DIC display from one to the other when the
E/M button is pushed on the dash. This is a wire that
is not necessary for the DIC to function, so if you do
not have the wire, then just leave it unconnected.
Wire H = BLACK. This is a ground. I hooked this up to
the BLACK wire connected to the cigarette lighter
light.
Driver Info System was not available 92+.
You will not find a new cutlass with one. If you put
one in your car, then it will go where the storage
cubbyhole is under the ashtray. The screw-holes for
the 98 Regency’s DIC is identical the Cutlasses, so it
will go there with no problem. If you get the DIC out
of a Cutlass, then be sure to get the storage pocket
as well. IF (OR WHEN) you get the HUD, then the
control switch will go where the storage is. 89-90
cars got a little pocket in the empty space. HUD
control panel was mounted above the headlight switch
(below the dash pad).
91 cars got a little pocket if they didn't have HUD.
Cars with HUD got the control panel instead of the
pocket.
Is your headlight switch up high next to the
speedometer with the foglight switch next to the air
vent? If so, then the HUD switch goes in the pocket.
My car headlight switch is located next to the vent,
with the foglight switch next to the speedo. (INT'L
models also had the BASS BOOST switch as well as the
foglight switch) But I will still put the HUD switch
next to the DIC.
Thank you i finally found the pinouts i have been searching so hard for. :mrgreen:
ah ha, glad to see you found it. I remember this thread from back in the day :lol:
this was the only post that did not have an expired webpage. Waht has to be done t make all of the features operational on a 94 cutty
I PM him. My question is where does the chip go. Am i going to have to mail something to him so he can do work or do i just put it in somewheres lol. I feel dumb lol :redface: :question: :question:
it depends on what he has. The one I bought from him was a reprogrammed chip from something else, he just redid it. If I remember right, you can either have a chip reprogrammed, or mine is an add on, basically using my stock chip still, just with another chip in between. All you have to do is get to your computer box and take out the screws, and then pop out the chip, and replace or add the new one, depending on what you get
youre probably out of luck then for fuel econ. i forgot that on top of the 94 computer you also have to compensate for engine size. so yeah, dont think anyone's figured out the 94 3.1 rate :sad:
