sl3196 Posted January 4, 2004 Report Posted January 4, 2004 I replaced my power antenna and it went in just fine but when I turn it on the motor keeps turning and wont stop. Also it keeps blowing fuses. What would be the cause of this? Quote
Shaners Posted January 4, 2004 Report Posted January 4, 2004 Did you replace everything or just the mast? If you replaced just the mast, then possibly you have the nylon cable in backwards (180 degrees off), or there is a piece of the old nylon cable still inside the housing, or the drive gear is stripped. If you replaced the entire unit (motor and all) then something else is wrong... Quote
sl3196 Posted January 5, 2004 Author Report Posted January 5, 2004 I replaced just the mast and it worked at first but the the motor wont stop turning when the antenna is going up. Quote
