tgpguy21 Posted November 11, 2002 Report Posted November 11, 2002 whats the biggest altenator available for the tgps? my lights dim when i push on my brakes and i want those babies to shine without melting all the wiring of course..... Quote
TGPilot Posted November 11, 2002 Report Posted November 11, 2002 I am pretty sure that the stock TGP altenator AMP rating is 105 amps. If you are getting a dimming when you step on the brakes you may want to have your alt and battery load tested first. I had this problem and I found out my alternator was dying and my battery had 2 dead cells in it... 8) Quote
Jeorge Posted November 11, 2002 Report Posted November 11, 2002 well I went to a 130 amp with out loosing somuch low RPM power like you would with a 160 amp.....I love my Alt I can Jump start any car with it....LOL but thats a different story Quote
Guest Anonymous Posted November 11, 2002 Report Posted November 11, 2002 Where did you find a 130 amp alt.? Quote
Jeorge Posted November 11, 2002 Report Posted November 11, 2002 the Greatest shopping place there is EBAY.....it was 48.00 shipped to me with a new belt too......when I get home if I have time I'll look and see that the Brand is.... Quote
musthavemuzk Posted November 11, 2002 Report Posted November 11, 2002 i local shop told me they could rebuild the 100 amp alt on mine for about $85-100. this was going from 100 amp alt to a 140 amp alt. they just had to order a new stator. Monty Quote
TurboZ24 Posted November 12, 2002 Report Posted November 12, 2002 Iceberg makes a 140 amp kit for the 105 amp GM alternator. It has high end components, bigger bearings, and a heat sink on the case. Quote
Guest Anonymous Posted November 12, 2002 Report Posted November 12, 2002 Do they have a website? Iceberg that is. Quote
TurboZ24 Posted November 12, 2002 Report Posted November 12, 2002 Here are my alterntor links: http://www.mralternator.com/ http://www.alternatorparts.com/ they carry Iceberg Kits Quote
tgpguy21 Posted November 13, 2002 Author Report Posted November 13, 2002 am i gong to have to switch wiring harnesses with any of these? Quote
ismellrealbad Posted November 13, 2002 Report Posted November 13, 2002 considering the 2.8 and 3.1 are nearly identical engines, would that alt for the 90-93 3.1's work on an 89 2.8? i dont see why not Quote
Guest Anonymous Posted November 13, 2002 Report Posted November 13, 2002 I'm pretty sure they are the same. In fact I got one off a 2.8 for my TGP from a j/y. Quote
ismellrealbad Posted November 13, 2002 Report Posted November 13, 2002 alright that sounds good Quote
Guest Anonymous Posted November 13, 2002 Report Posted November 13, 2002 I just looked up some part #'s. The '88 shows a different part number than 89 and 90. The 89 shows the same # as 90 for an AC Delco alt. and different #'s for the other brands. The only difference I see is the alt. for the 3.1 is 105 amps. The others are 100 amps. Quote
ismellrealbad Posted November 13, 2002 Report Posted November 13, 2002 im more concerned with whether they will fit on the mount or not Quote
