Dannymik Posted January 3, 2004 Report Share Posted January 3, 2004 I know this has been on here a bunch, but I need a quick answer on how to adjust my door switch. When I go to open he door from the outside I pull on the handle and the door will not open unless I pull really hard. So I went outside and opened the cover and took this picture. Now what do I adjust...any specific tools needed. Thanks Dan Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 3, 2004 Report Share Posted January 3, 2004 See the threaded rod? Unclip it and turn the barrel up. Give 2 or 3 turns at a time and try it. Quote Link to comment Share on other sites More sharing options...
Dannymik Posted January 3, 2004 Author Report Share Posted January 3, 2004 See the threaded rod? Unclip it and turn the barrel up. Give 2 or 3 turns at a time and try it. ok....I'm going to give it a try! Quote Link to comment Share on other sites More sharing options...
Dannymik Posted January 3, 2004 Author Report Share Posted January 3, 2004 Ok turby...the non threaded rod controls the lock assembly. The threaded one is for the handle. Anyways I unclipped the threaded rod and adjusted the little "nut" on it upwards and the door is opening fine. I've had this aftermarket part for a little more that 2 yrs acting up on me. These door handles are as bad as our brakes . Thanks turby! Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 3, 2004 Report Share Posted January 3, 2004 No problem. That's why the board is here. Quote Link to comment Share on other sites More sharing options...
