Which DOHC heads?
What combination of heads/block mate up to give the highest compression ratio. Can it be done without any interference (aside from timing belt)?
I was told to put I believe 91-95 heads on the 96/97 block to give a CR up over 10 I think.
are the pistons different? At the top of the stroke are they flush with the top of the block?
The 96+ pistons have more of a dome. I believe they stick out of the block at top of the stroke.
the pistons on my 95 block stick out above the deck and it came that way from gm. on the chambers being smaller i don't know
