OldsmoBeast Posted December 29, 2003 Report Posted December 29, 2003 I know this topic has been beaten to death but someone recap with me. Is it possible to swap out a 4T60-E in order to mate a Getrag 282 with a 3100? (97 cutlass)...How much money and time will be involved? Is this going to be something i can do over a span of 1-4 days? How long would i have to save up? Don't worry about the parts list, i can get that easily. Thanks! YK Quote
Guest TurboSedan Posted December 29, 2003 Report Posted December 29, 2003 your BIG problem will be mounting the clutch pedal. since your car is a '97, there is no way to mount the clutch pedal without a custom bracket. i know brian89GP has done it with his Grand Prix tho, so you may want to talk to him and/or check out his webpage. another problem may be your cars engine management system - the computer might not like it. i did the swap with a 3.1 MPFI engine and simply swapped in an ECM with the right memcal so it was easy for me. the price will all really depend on what kind of deals you can get. the only new parts i used were engine & tranny mounts, and an axle. the tranny i got already came with a new clutch. i could do the swap within 4 days easy but only because i've done it a few times before. it all depends on how mechanically inclined you are, whether you have all the tools. i think the whole job is pretty easy really, but then again i'm sure a '97 would be quite a bit more difficult. good luck joshua Quote
soccrplayrgtp Posted December 29, 2003 Report Posted December 29, 2003 take a look at my cardomain page.. that may help you out some. i did a 284/DOHC in my 94 GTP (new style firewall/underdash) http://www.cardomain.com/id/soccrplayrgtp Quote
OldsmoBeast Posted December 30, 2003 Author Report Posted December 30, 2003 okay cool......so if I could get my hands on a 282, Am i going to have to rearrange anything other than the fabrication of the brackets and stuff? Do I need the insides of different axles or something? and i could probably use the memcal from a MPFI, right? has anyone ever done this swap on a 3100?! thanks YK Quote
cutlassdude96 Posted December 31, 2003 Report Posted December 31, 2003 you will need the computer from a 3.1 5sp for it to work Quote
OldsmoBeast Posted December 31, 2003 Author Report Posted December 31, 2003 but with the computer from a 3.1 5sp...like for example the 93s or something like that...would i lose anything? fuel economy? performace? would the engine operate properly? or would i just be driving an MPFI as opposed to an SFI? Quote
cutlassdude96 Posted December 31, 2003 Report Posted December 31, 2003 it should run the same but you will be running MPFI instead of SFI Quote
Robby1870 Posted December 31, 2003 Report Posted December 31, 2003 You'll need more than just the MEMCAL. You'll need the whole computer and wiring harness from a 2.8/3.1L 5spd. 282's were only available in W-bodeis from 88-90 Quote
slick Posted December 31, 2003 Report Posted December 31, 2003 Werd. How else would you wire that sucker up. EDIT: This may be helpful. Those beretta guys have been doing this swap forever now http://heavywoody.berettatalk.com/Pics/5spd_Swap/. Quote
dbtk2 Posted December 31, 2003 Report Posted December 31, 2003 i could do the swap within 4 days easy but only because i've done it a few times before. it all depends on how mechanically inclined you are, whether you have all the tools. i think the whole job is pretty easy really, but then again i'm sure a '97 would be quite a bit more difficult. good luckjoshua So if someone were to buy all the parts, and go to your house, and give you a small sum of money, would you help them do a 5 speed swap on say a '90 Turbo STE? Shawn Quote
