DOHCRagtopguy Posted August 11, 2002 Report Posted August 11, 2002 I tried out my CD player , but it came up 'error' and spit it out. Any clue about what the problem would be, is it an expensive repair? Would like to keep the unit, love the wheel controls. Quote
NORBI Posted August 11, 2002 Report Posted August 11, 2002 MIght be that the CD doesnt go all the way in and since it might be not getting all the way in inside it throws the CD back. Quote
NORBI Posted August 11, 2002 Report Posted August 11, 2002 This usually is expensive to fix because those are vey delicate parts and they wear out very quickly and a pain to change. My friend had this trouble before and had to wait to get it fixed couple weeks and after it got fixed had same problem after couple weeks. Quote
92Cutlass4Dr Posted August 13, 2002 Report Posted August 13, 2002 I'd say to either check a junkyard or get an aftermarket deck. you can set up an aftermarket deck to use the steering wheel remotes, but only if the aftermarket deck comes with a wireless remote. it costs about $50 for the part to adeapt the steering controls. Quote
GnatGoSplat Posted August 13, 2002 Report Posted August 13, 2002 Probably needs a new laser head. I've had many CD players go bad, and that's usually what they need as the laser wears out pretty quick. Sometimes you can crank up the laser power a little bit by turning a teeny weeny little trimpot on the laser assembly and that will make it work for awhile. Quote
