srsheely220
well i finally blew the engine on my 1995 grand prix 3100. I have the engine all prepped for pulling but were the engine and tranny are bolted together i cant get to 2 of the bolts because of the inspection plate being tiny and the engine being siezed up and not able to be turned by hand. i was wondering if there was away to get the engine out w/out pulling it with the tranny as well.
thanks
Guest Gp crazy
will it turn over with the starter ? if not you are going to some how turn it over. :!: good luck 8)
If siezed and cannot rotate the flywheel, you'll have to pull the entire drivetrain to gain access to the bolts.
Once out, you *should* be able to unbolt the engine from the tranny.
- Erik
thanks
Im assuming its the converter to flexplate bolts you cant get out.....ok, here is a fix, take EVERYTHING off the left side (facing car) of the engine bay. Take the pulley off. As you lift the motor, put a floor jack with a thick sheet of plywood under the tranny and jack it up at the same time. You will be able to pull the converter off the tranny input shaft. When it comes time to reassem, just use new seals on the input shaft/stator support and you should be ok
oh I should add - make life easier, take EVERYTHING off the motor u can first - intake, heads, water pump etc etc the more u get off the lighter it will be to monkey around
