90TGP Posted December 25, 2003 Report Posted December 25, 2003 I know that my factory off-set is 25mm with a 16x8 wheel. The wheels I'm looking at have the smallest available off-set of 40mm on a 17x7 wheel. A 15mm difference which comes out to be 5/8". I was wondering if a 1/2" wheel spacer (4mm shorter) would be adequet enough to place the aftermarket wheel into proper alignment? Any opinions? P.S. My stock tire size is 245/50/16. If I went with the 17x7, would it be safe to keep the 245 series tires, or go with a smaller 235 series tires? Thanks Quote
patgizz Posted December 25, 2003 Report Posted December 25, 2003 235 and 245 is not the tire series, it is the width. /35, /45, /50 - that is the series. 225/60/16 is a 60 series tire. 225 is the width in mm, 60 is the sidewall height as a percentage of the width(225) and 16 is the wheel size. so you would want to go with a 245/45/17 tire to keep the same overall height(within .04 inches) to keep your speedo reading the same and to ensure you do not run into rubbing problems. Quote
90TGP Posted December 25, 2003 Author Report Posted December 25, 2003 Hi. I forgot what everything on the tire was called. But I was meaning the width Quote
