Pic-Exhaust
Looks pretty stock to me, those exhuast tips are a definite stock item. And if that exhuast is off of a 93' that was in a junkyard its probably safe to say that its an original piece since most first gen W's are still rolling around with their OEM exhuast.
post pictures like this http://www.members.aol.com/dbroncouno/images/picture%20002.jpg
that publish bullshit prompts me to download pictures instead of just loading them in a new window..just use the "http://www.members.aol.com/"your sn here"/images/"file name here"
does the prompt to download come up for everyon else? 8)
Anyways, those look like some of the stock tips I've seen before on cuttys
Those are stock tips. They're the dual rectangle tips all dual exhuast equipped Cutlass's had up untill 94' when they switched to the two pipe per muffler look. That or they're really good facimalies of them. The only other tips I know of that look like that came on 91 and 92 Toronado's and they were substantially wider and didn't came attached to a camaro type transverse dual exhuast setup.
I'm not sure about the cat, could you give a closeup of that section? And actually your car appears to be missing the resonator as well???
Your not 100% right there..
The exhaust that 90Kutty posted is the stock dual exhaust from a 3.1 equipped Cutlass Supreme. ANY 3.1 Cutlass with the dual exhaust option got that style of exhaust (my bro has a 91 Sedan next door with that option).
Any 3.4 DOHC equipped Cutlass got the dual pipe exhaust. (Of which, only one of those pipes is actually functional, the other is a dummy pipe for looks)
Also, I don't believe the 3.1 cutlass's (or W-bodies) had resonators. I think those were a required item for the DOHC to tame the raspiness in the exhaust.
that's correct for the 3.1 w/ no resonators..I wonder if the 94 Lumina w/ the 3.1 MPFI got a res or not :?: ..as the 3100's they started putting in the cars in 94+ got resonators, I believe the 3800 Regals had resonators in 93 at least though..not sure on the DOHC's, but they probably had them pre-94 as well.
EDIT: btw, that cat looks normal/stock to me, but it *might* be hollowed out or something, I don't remember how my cat was on the car, but I believe the weld was cleaner on mine...but who knows, I haven't had a cat since April, 2002 :wink:
my Z has a resonator.... at least one, :lol: haven't looked under it in a looooooooonnnnnnnnnnnnnnnnnnng time
they look like Z34 tips to me :?
Stock Z34 tips:
ok there were oval wasnt quite sure
