Car Weight Research, please post some easy to find info
On the driver door there should be a sticker with the weight of your vehicle. What I want to do is get a list of these weights with the year, make, model, engine, trans, number of seat belts.
What I have so far:
92 grand prix se coupe non B4U DOHC 5 speed 5 seatbelts = 4314 lbs
92 cutlass coupe SL DOHC auto 5 seatbelts = 4366 lbs
96 cutlass sedan 3100 auto 5 seatbelts = 4370 lbs
Now, from what I have read you sutract 180 per seatbelt to get the car's actual weight. I dunno if its accurate but im just collecting the sticker weights for now.
1993 Lumina Z34 Auto 5 seat belts - 4388lbs
hmmm.... so my Z is supposed to weigh around 3488... at least I'm only 200lbs or so overweight :lol:
92 Grand Prix LE sedan 3.1L ---> 4395lbs, 5 seat belts
I'll check my sis's 95 Monte Carlo when she gets home
93 Cutlass Supreme Convertible
4 seat belts
4547#
Wife's sticker is washed out, sorry.
I thought you take the vehicle's curb wieght because my Z34 according to motortrends tests are 3700. But IDK.
Thanks, so far its making sense. I know that some cars got larger gas tanks as well, which will factor in a few pounds. Isnt it 16 pounds per gallon of gas?
Keep em coming:)
1994 Cutlass Supreme LS Sedan 3100 ATX
6 Seatbelts (if you include the one in the middle up front) -> 4421lbs
yea now i know why my car is slow :o (Power to weight ratio ~ 1:20)
However, if the seatbelt thing is right...she weighs 3341lbs
Online sources tell me that my car weighs: 3405lbs
so i guess the seatbelt subtraction is reasonable...just maybe a little too much? :?
Curb weight on my Bonneville is 3,633lbs. Width is 74.2 inches
Curb weight on my GTP is 3,396lbs. Width is 72.7 inches. Info was taken from Edmunds.com
Aaron
http://autos.msn.com/research/vip/spec_Exterior.aspx?modelid=2449&trimid=-1&src=VIP&tab=2&sub=3
wtf? they have the auto weighing less than the manual..can that be right?
anyways, you guys are obviously stating the GVWR rating of the vehicle, not the actual weight..because that is what is listed on the door stickers :wink:
GVWR = "Gross Vehicle Weight Rating refers to the maximum loaded weight of a vehicle, including fuel, fluids, and full payload." meaning the weight of the car + what it can tow/haul as far as I know. 8)
edit: if you've never read this, then it explains the weight thing..lol http://www.wecamp2.com/weight.html
Yeah, thats what it is, but I dont think it refer to what it "can" do but rather what it weighs with full fluids and an average person in every seat. 180 pounds is said average weight.
I understand, and with the 180lb method, it works out about even with the weights listed at most online sources.
ok, 6 pounds per gallon, not 16. hehe, i knew there was a 6 in it:P
Im not interested in edmunds, just the info I posted originally.
forgot to post my #'s ..btw, are you only wanting 60* cars?
1993 Grand Prix SE coupe 3.1/auto 4209lbs 5 seatbelts BYP package also...
2001 Grand Prix GTP sedan 3.8/auto 4518 lbs and 5 seatbelts
i can sort through them later, i just want the W bodies which is why i posted here. This started on 60v6 in a BS thread about 'post something about the dork above you" so I brought it here as a decent thread.
I find it hard to believe a 3.1 convertible can handle more weight than a 3.4 DOHC coupe.
